Old 02-13-2014, 12:23 PM
Default DSE Hydroformed subframe and pwr steering fittings
How have you guys been able to install and tighten the power steering hoses to the steering rack? The return side fitting is impossible to install without unbolting the rack and forcing it down a bit. When I got the 6an fitting on threads, I found it impossible to fit any kind of wrench there.
Sorry for the crappy iphone pic, but you can see return fitting behind pressure side fitting.
And all DSE stuff
Is there something I can't figure out here?
63 Z06
Old 02-13-2014, 01:25 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
they were hard but I did tighten one first then the other but cant remember which one was first.
Old 02-13-2014, 01:30 PM
69Pressurized's Avatar
69Pressurized 69Pressurized is offline
Sometimes a Crows Foot wrench will work in those areas
Old 02-13-2014, 03:17 PM
Musclerodz's Avatar
x2 easiest way to do it
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-13-2014, 07:49 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
That's what I used as well.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 02-13-2014, 08:42 PM
Me too, with a uni-joint
Old 02-14-2014, 12:21 AM
I knew i wasn´t alone with this. Look´s like i need to do some shopping..
Anything special in crowfoots or just regular fleaybay time ?
Thanks guys!!
63 Z06
Old 02-14-2014, 12:47 PM
Thanks guys!!
get a tube style, more better.
Old 02-26-2014, 11:49 AM
frankv11's Avatar
frankv11 frankv11 is offline
Does any one have a part # for those fiitings. Preferably xrp
Old 02-27-2014, 11:35 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I don't have part numbers, but DSE sells the fittings on their website. I would just buy them there.
As for the best way to tighten those fittings down, or undo them, should you need to, it is easiest to just unbolt the two main bolts on the rack and slide the rack out a bit. I've had to work on this setup about a dozen times, and the last time was at Optima when I broke a rack. Andy from DSE helped get it all back together and tightened the fittings before bolting the rack in place. It may seem like more work, but it is considerably less frustrating and, I think, faster as well.
