Old 08-02-2006, 12:56 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Racelogic Traction Control
Hello:
Has anyone used the traction control from Racelogic?
Are they known for making a good product?
Thanks,
tyoneal
Old 08-02-2006, 06:06 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Not yet.
My LS7 69 Camaro
Old 08-02-2006, 08:03 AM
camcojb camcojb is online now
Yeah, mine is in my shop awaiting install on my new Chevelle.
Old 08-02-2006, 09:15 AM
J2SpeedandCustom J2SpeedandCustom is offline
Yep it's awesome!
Jeff Allen
J2 Speed and Custom
Old 08-02-2006, 02:38 PM
uk68327's Avatar
uk68327 uk68327 is offline
Thumbs up
Should be excellent, Aston Martin and Lotus use them as standard fitment....and probably many others......
http://www.racelogic.co.uk/
Old 08-02-2006, 03:08 PM
68protouring454's Avatar
Default how much
guys how much does a set up run?? also can it be used in 12 bolt/10 bolt/ ford nine inch?
Old 08-02-2006, 03:30 PM
Blown353 Blown353 is offline
The box is about $1200 AFAIK, and you will need front and rear speed signals to feed it then you need to tie into your distributor and injection to signal timing and/or fuel cuts. For a car with factory ABS you can simply use the existing WSS signals; for a retrofit application they can provide magnetic pickups and you can make your own brackets for them and point at the backside of your wheel studs (or bolts for your brakes if you have 2-piece rotors.) All you need is metallic object(s) to pass very close to the pickup to send the signal, then the rest of the setup is taken care of in the software (how many signals per rev, tire diameter, etc.)
They have the complete software manual on their website, good reading to understand how it works-- minmum activation threshold, maximum allowable front to rear difference to allow for turning, launch control, etc. Then there is the actual power limiting functions such as retard timing initially, then randomly cut every Nth injector pulse, etc.
Very cool unit, looked into one many months ago.
1969 Chevelle
Old 08-02-2006, 07:08 PM
Marcus SC&C's Avatar
I haven`t used it but I did look into it in detail for a customer project years ago and I was impressed. It should be a well proven system by now. I`ve been mentioning it to everyone who orders a Street Comp-AFX package from us with ATS`s aluminum spindles and C5 hub/bearing packs. The wheel speed sensor and wiring is already there so you only need to install pickups for the rear. I`m suprised aftermarket anti lock brakes haven`t taken off either. Mark SC&C
Old 08-02-2006, 10:21 PM
tyoneal's Avatar
Thanks for the information.
When I read the web site, it loked like it would be an excellent addition to a big horsepower engine. Especially if your not use to driving one, or you would like to teach someone to drive one.
I'm hoping someone who has one will also jump in and give us their experience.
I definitely would like to leave open the possiblity of adding this at a later time.
tyoneal
Old 08-03-2006, 10:49 AM
rwhite692's Avatar
Anyone have any experience with the Racetronics traction control unit? Is it a "brake-only" type of system (no engine management interface)?
Project update thread here:
My Lateral-G Page
My Shop Build:
