Old 05-29-2014, 09:50 PM
Lrayzer Lrayzer is offline
Thumbs up
This is what I call timing, our 78 is torn apart right now, and we have been looking at the options short of making everything from scratch, your upper crossmember is very close to our paper napkin design, if nothing else we would like to start with that pc and add as budget allows, do you use solid or poly bushings in the crossmember ? I want to firm up the car, noise and ride are secondary.
Any pricing targets ?
Nelson Competition,
Motorsports Fab and Brewery Werks
"Home of the G-Rip Relocator"
Once you are on the trailer it's all about the bench racing and the beer
The Stable:
3 Grand Nationals
1 67 Camaro
1 96 SS Impala
1 92 GMC 3500 F/I 489 CID, Custom dually
08 VSCRDX, Vivid black
78 L-82 Vette, PPG Black Cherry, Father-Son project resto-mod in process
And a couple drivers...
Old 05-30-2014, 05:09 AM
Supporting Vendor
BadBird,
I posted this over on Pro-Touring, so I thought I'd just paste it here so everyone can see it as well:
1) Does the new rear crossmember raise the differential for improved toe control?
As per the "Vette Improvement Program" articles written around 1985 and the "Chevrolet Power" book written in 1984 the desired changes at that time were to raise the rear differential and lower the strut rod mounts at the diff.
When we designed this kit we had the luxury of 30-odd years of others playing with this suspension, so our first item of business was to read as much as we could.
Though we used the VIP and the Power Manual as a starting point we further altered a few things to get the most out of the geometry.
We did raise the diff slightly (though raising it too much becomes an issue on the early cars as the rear u-joints want to hit the body), and lower the strut rods.
Basically what you are trying to do is get the axles and strut rods in the right place to achieve the desired toe and camber gain changes and roll center at the desired ride height.
So, to answer and further elaborate on your question, yes we did change things to achieve the desired toe, camber and roll center. We also use heims on the strut rods which allows us to eliminate the eccentric bolt and still change static camber with all parts on the car.
2) Can the front steering arms accommodate more conventional balljoints?
The steering arms have a taper machined into them (just like the OE units). We use a tapered adapter to mount the heim end. However, you need to be careful, if you move the location much it will have a dramatic effect on the steering geometry; and it may cause interference with the rim.
Why would you want to change it?
Skunk Werks
Ridetech
www.ridetech.com
Old 06-24-2014, 02:19 AM
Originally Posted by Rod P View Post
well one of the really cool projects here has been for the corvette guys is our new coil over system!!!! Hope you guys like the sneak peek at the newest stuff in the pipeline!!
complete rear system!!
It is about time to get something new for a vettes too. There is a lot of potential customers in C2-C3 genre.
63 Z06
Old 06-24-2014, 11:27 AM
Rod P's Avatar
Rod P Rod P is offline
wait till they see these cars run!!! holy smokes there quick
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 09-22-2014, 02:04 PM
Rod P's Avatar
heres a few pictures of the system going on to a show frame
Rod Prouty
Bangshift Stories
