Old 08-15-2006, 10:25 AM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
Default HEI Distributor Recommendation for ZZ3 Crate?
Does anyone have recommendations for an HEI distributor for a ZZ3 crate motor? I have been chasing down an issue and I believe that it is with the current HEI distributor I have. Thanks for the help!
Old 08-16-2006, 11:40 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Are you currently using the HEI that came with the engine?
What issues are you having?
Old 08-16-2006, 11:48 AM
I am using a rebuilt Mallory HEI (8 years old), and I seem to be having problems with the coil or some other part of the ignition system. I don't seem to be getting all 8 cylinders firing, and the plugs were fouled worse than I have ever seen before. The car will idle just fine, but when the car is throttled up the car spits and sputters. At first it was acting like a carburetor problem, so I replaced the old Edelbrock performer with a new Holley and this did not fix the problem. I also put new plugs in it and this also didn't help. I currently have the distributor at a local shop and they are putting it on their distributor machine to test it.
Old 08-16-2006, 12:10 PM
MaxHarvard's Avatar
sounds more like a fuel issue or timing. A coil wont usually do that.
