Go Back   Lateral-g Forums > Technical Discussions > Man Caves
Old 10-18-2014, 05:50 AM
Default Lift placement
I am just getting started on my shop and was wondering where to set a lift in it. It is 42x42 12'ceilings 2 overhead doors. Doors are 12x10 and 16x10, in the 12x10 I will keep my trailer which is 30' long and the rest will be open. I just want to rough in power for it for now so I was going to hardwire a so cord out of the ceiling and drop it down to it. Have no idea what lift I am going to purchase or when I am going to purchase it. Is the power hookup usually at the bottom or the top of the lifts? 120 or 240 volt? I want it out of the way so I don't have to work around it all the time. Thanks
Kevin
Old 10-18-2014, 08:16 AM
Sieg's Avatar
Sieg Sieg is offline
First you need to decide two or four post lift. Ceiling height restrictions?
Then draw yourself a floor plan with door openings and critical clearance measurements and start filling in the spaces with workbenches storage shelves and spaces, compressor, tool boxes, and power tools.
Then factor the minimum work/access space needed around the vehicle.
That's a decent start.
Old 10-18-2014, 08:35 AM
Bryan O's Avatar
Bryan O Bryan O is offline
I'd suggest an American made two post asymetrical. Here's a pic of the Mohawk A-7 I just had installed in my garage. You can clearly see the electrical hookup. Its 220.
Bryan
Project Alchemy
https://lateral-g.net/forums/showthread.php4?t=29820
Old 10-18-2014, 04:03 PM
Old 10-18-2014, 05:11 PM
Bryan O's Avatar
I resemble that vid.
Bryan
Project Alchemy
Old 10-18-2014, 05:16 PM
Make that 2 of us.
Old 10-18-2014, 08:48 PM
Shmoov69's Avatar
Shmoov69 Shmoov69 is offline
One of my favorite lines! LoL!
Jimmy
69 Camaro - Twin Turbo'd
58 Nomad -348 Baby Rat
www.fquick.com/shmoov69
Old 12-22-2014, 07:02 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
With that size shop I would highly recommend a 4 post lift with optional caster wheels so you can move it around the shop as needed and even out doors if needed. A typical 4 post lift runs on 110 so you could run an extension cord as needed. A 4 post does not need to be permanently anchored and will work on any floor that will support the vehicle weight. My 4 post is not anchored and it survived a 6.8 earthquake here in VA a few years back with no ill effects to the lift or to Dust Off which was 6ft in the air at the time the quake struck. There are pros and cons to both styles of lift so take some time to decide which will work for your situation.
See my lift light post here for lighting ideas.
https://lateral-g.net/forums/showthread.php4?t=48550
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 12-31-2014, 07:46 AM
Drop 220/240V from the ceiling on the passenger side - usually the controls are on the passenger side. So that's the shortest route - but you can always come across the top with power if the wall is on the driver side.
You have enough ceiling height for a nice two post asymmetrical lift. Don't cheap out here like I did the first time around. A lift is like the greatest tool EVER in your shop. You'll be shocked how much it's used.
Old 12-31-2014, 09:56 AM
Make sure your floor design will meet the two post lift requirements if you go that route.
Having worked on both, I would only recommend a four post for storage or light duty work. If you're serious about building a car in the shop and using the lift to help, go two post.
