Old 10-27-2014, 06:54 PM
BanditDave BanditDave is offline
What I'm trying to figure out is why the hell is there no videos posted yet?! Pretty rude of the OP if you ask me... Lolol
Sweet ride!
Old 10-28-2014, 02:48 PM
Sweet ride!
Me too what gives?
Old 11-12-2014, 11:29 AM
MattG's Avatar
MattG MattG is offline
Easy fellas...!!!
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 11-12-2014, 12:02 PM
Ron in SoCal's Avatar
Originally Posted by MattG View Post
Easy fellas...!!!
Your throttle operates your windshield wipers! Why didn't I think of that??
Ron in SoCal
69 Camaro in progress
Old 11-12-2014, 02:52 PM
MattG's Avatar
Took me two hours to fix that! Still not sure what wire was setting them off, but damn annoying for sure...
Old 11-13-2014, 09:29 PM
Matt what did you do for a tank/reservoir for the heat exchanger and where did you put it?
Old 11-14-2014, 08:29 AM
MattG's Avatar
I used the stock tank that comes with a 2010 Camaro kit. Mounted it just to the PS of the radiator. Lots of options for this. I ran the lines thru the PS of the fender and have the pump located just to the side of the lower inlet to the heat exchanger. Works real good.
Old 04-30-2015, 02:34 PM
cwylie cwylie is offline
You have a part number for that inter cooler resi by chance?
Old 07-05-2015, 07:10 AM
MattG's Avatar
its the stock one from Magnuson that comes with the 2010 Camaro kit.
Old 07-05-2015, 03:25 PM
Nice work! Is your crank pulley pinned ?
