Old 12-15-2014, 09:46 AM
wiedemab's Avatar
wiedemab wiedemab is offline
earlier pics -- -
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-15-2014, 09:48 AM
wiedemab's Avatar
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-15-2014, 09:50 AM
wiedemab's Avatar
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-15-2014, 09:54 AM
wiedemab's Avatar
I'll just skip ahead. The majority of the DSE Quadra-link is welded in place. The inner and outer wheelhouses, quarters, tail panel etc. is all screwed into place and fit up. A few more things to check and then I'll blow is back apart for the last time, button up some welds and then put everything back permanently.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-15-2014, 10:33 AM
Looks great, Brandon. Did you do anything to treat the metal that's hidden, like the inside of the frame rails, since you had access to some of it?
Old 12-15-2014, 11:11 AM
wiedemab's Avatar
The Dynacorn parts either come coated with their weld-thru or the standard new part black (probably crappy - primer). Where I was going to weld or had ground, I either used weld-thru primer or in some cases used epoxy primer.
Could I have coated it more uniformly and thoroughly, probably yes........ Much of the framerails gets welded on to install the DSE stuff and what I had sprayed on the inside of the rails was burning back off in those areas. I may coat the inside of them with
http://www.amazon.com/Transtar-4423-.../dp/B00H2W3YZW
We've used it with some success in the past. I would do this once it is on the rotisserie so that I can spray it from multiple angles etc..
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-15-2014, 03:42 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Wow, Loads of progress! Your work is looking great, almost looks like a car again. Did you get the lower link mounts welded in yet? The directions are kind of odd there. I had to call and double check a few measurements with dse.
Old 12-15-2014, 03:57 PM
wiedemab's Avatar
I haven't welded those on yet. I read the directions and thought I had it figured out, but just to double check I took some measurements off of their display when I was at Charlotte Goodguys. I wanted to be able to verify their location by taking diagonal measurement from the upper links.
The things that I've ran into so far that - -aren't a big deal, but were little speed bumps along the way are:
- Dynacorn rails seem to be slightly taller than the factory rails, which left a little bit of a gap between the inner stiffeners (from DSE) and the top of the rails. It just left more of a gap to fill with weld than I would have preferred, but not a big deal.
- I cut out the trunk pan using the DSE templates, but I didn't have any wheelwells to reference. If I had them, I believe I would have positioned the template against the wheelwell and not the edge of the trunk pan. This resulted in me notching too much away on the trunk pan. Again, not a big deal, I'll just remake that part of the trunk pan and it'll look like I never did it.
- Both quarter panels fit really well
- the tail panel was too wide so we drilled it apart and repositioned it
- the outer wheelhouse and trunk drop-off on the passenger's side fit pretty poorly and had to be split and pulled to make fit.
- The rear seat pan drop-off (the piece that the upper DSE mount welds into) was in pretty bad shape on my car from a chunked driveshaft and some rust. I tried to buy a replacement, but nobody had it. I took mine all apart and fixed it. I have everything tacked into place, but in order to weld all of this more easily, I will probably finish the welding on the rotisserie.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 12-15-2014, 06:54 PM
kevin_l's Avatar
I noticed you notched the rails for the torque boxes, I wasn't sure why but I didn't know the rails where taller. That makes since now, My driver side mini tub cut was off some too, I didn't catch it until after I had already boxed the rail back together so that tub was a pain to get in but with some clamps and vise grips I was able to over come the poor fitment.
Old 12-15-2014, 07:05 PM
wiedemab's Avatar
I notched that rail because it wasn't trimmed properly. The rails aren't much taller, but are a little different. I need to measure to verify. The tolerences on these cars weren't good from GM, as I'm sure you've seen
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
