Old 07-14-2014, 08:39 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Default '67 Chevy II Project
I've said that this will be a race capable street street car --or the other way around...not sure.
The plan is pretty standard.
DSE Catalog for Chevy II
LS powertrain TBD
T56 Magnum and other drivetrain goodies from Bowler
C6Z06 brakes to start with
Pretty stripped down minimal interior
Full Cage
Blah, blah, blah
I bought the car for really cheap, knowing fully that it was a beat up, rusty old drag car from the midwest and would need just about every panel...but it was cheap and I like to do fab work, so here we go.
Here is what I started with.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:41 PM
wiedemab's Avatar
Here it is when I brought it home and started to tear into it --- it was even more rusty than I thought.........are they ever less rusty?
Let the tear down begin
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:43 PM
wiedemab's Avatar
Forklift is a must have for working by yourself!!
Skip over a bunch of pictures of me simply documenting how rusty it is and here it is on the nice frame table that Billy from B&B Classics hooked me up with.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:46 PM
wiedemab's Avatar
Default Bracing up the body
Here are few of the bracing I started with on the body. Not the prettiest tubing, but I had it laying around.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:48 PM
wiedemab's Avatar
Rear framerail locators (these will be needed later) and help support the body.
Supporting it as the rockers so that I can start removing the floors.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:53 PM
wiedemab's Avatar
Floors after I got to them with the plasma cutter.
Fitting up some 2X5" 1/8" wall tubing that will be tied into the inner rockers (new inner and outer rockers). This is an idea that I blatantly stole from DSE. They did this on Cheryl Herrick's car.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:54 PM
wiedemab's Avatar
Just more fitting.........
More Bracing.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 08:59 PM
wiedemab's Avatar
I won't bore you with pictures of all of the replacement panels - you'll get to see them eventually (I hope) once I get them on the car.
Door all fitted and gaps aligned etc.... then the rockers were removed.
Quarters rough cut out.
Another brace and some locator bushings for the front of the framerails (sorry about my finger in the picture).
I don't know why, but some Facebook pictures will not link correctly........... arghhhh
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 09:06 PM
wiedemab's Avatar
starting to remove some of the cowl --- - -- need to get back to focusing on one part of the car at the time.....so I will soon me back to focusing on the rockers and rear...
Also, notice the locator dowel for the lower fender bolt. I'll be remaking that part and wanted to make sure be able to locate it properly!
New inner rockers that Dad had bent up for me.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 07-14-2014, 09:10 PM
wiedemab's Avatar
Lining up the rocker panel - the inner rockers that we made were plug welded to the new Dynacorn rockers, then drilled again (between welds) so that I could plug weld the pinch weld to the 2X5 tubing. BTW..I bought some Roper Whitney punches for punching holes to plug weld - -way nicer than drilling them.
Clamping and fitting with some sheet metal screws, C-clamps, ratchet strap, whatever it takes! Dad found and old frame spec book for these cars so we've been checking everything as we go. This car was dead on so far, which is surprising since it was so rusty and beat up.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
