Old 01-04-2015, 03:26 PM
Ernie W Ernie W is offline
Default Question about CPP C5 uprights for 1970-81 F-body
Hi. I'm new here, mostly just read on the forum. I'm building a 1980 Pontiac Firebird with a 6.0L LS 6-speed. I'm fixing to pull the subframe to do some metal work on the firewall area. I'm looking to do some small suspension and brake work. I also have solid bushings and subframe connectors.
With the brakes, I plan on running C5 front and 98-02 Camaro rear disc setup. Are the CPP C5 uprights a decent piece? Or should I keep walking and go with the Kore 3 hub setup on a modified spindle? I'll be using GM rotors and calipers purchased new thru the shop I work at. Just looking for some feedback on the CPP parts.
Thanks,
Eric
Old 01-04-2015, 03:34 PM
The only advantage the CPP spindle will give you is a modern hub instead of individual bearings. Your stock individual bearings and spindle along with Kore3's billet hub is a fantastic piece for a street car. If you're going for a track car, you need to be in touch with SpeedTech and get the real AFX uprights along with the correct control arms. This will give you the altered steering and suspension geometry a track car needs and that the original AFX spindles were designed to accommodate.
Welcome to the site, Ernie. Be sure to start a build thread and show us the car. Good luck with your build, too.
Old 01-04-2015, 05:15 PM
Che70velle's Avatar
If your wanting a noticeable improvement in your front suspension setup, I'd give Ron Sutton a call. He can help you with everything you need, at really affordable prices. Don't tell him I said this, but he's a genius! You will be happy you contacted him. He is a vendor here, check out Ron Sutton Race Technology.
Thanks Dad!!
Old 01-04-2015, 05:31 PM
If your handy with a sawzall, cut off wheel and have access to a brake lathe there is nothing wrong with the 2nd gen spindle.
Just have your factory rotor machined down to be used as a hub. Trim the caliper ears and add a Kore3 C5 caliper bracket.
http://www.kore3.com/proddetail.php?prod=10081-01
Old 01-04-2015, 06:08 PM
You the man. I had stumbled across a pic that looked like the factory rotor cut down to make the hub but couldn't find any more info on it. I'm very glad you mentioned this. I'll have to go this route as most all I've read on the CPP wasn't the best.
I really wish I could afford to go with a full pro-tour style suspension but I don't have a large budget. I just want it to be better handling and more modern feeling. I'd like to one day be able to track the car some as the new track in Bowling Green is only a couple hours from me but for now just a street car with some spirited driving on the backroads of Kentucky.
I appreciate the help and suggestions guys, sorry for the newbie questions.
Old 01-05-2015, 09:05 PM
No reason to apologize. That's what this place is all about.
Old 01-06-2015, 01:50 PM
David Pozzi's Avatar
We tested the CPP spindles on Mary's car for a few events. The spindles were fine, the GMR hubs had some play and adjustment issues so we had to stop using them.
I would take the following into consideration and look at costs.
The stock spindle is OK, nothing really wrong with it, but to put larger brakes on it you have to cut the old caliper brackets off and bolt in an adapter bracket. The best stock spindles are the late second gen with larger outer wheel bearing. If you are using a floating caliper, the stock spindles work well and a taller upper ball joint can be used to help the poor camber gain. You need a hub to mount the rotor on since all second gen's came with disc only.
If you go to 13" or 14" rotors, along with non-floating calipers, then pad knock back is going to be an issue. How big an issue depends on a couple of other things:
If you have power brakes, the pedal moves half as much as manual brakes, this reduces pedal drop by half, so pad knock back is perhaps tolerable with power brakes, and terrible on a manual system. It also matters if the front and rear are non-floating calipers or just the front, and what size master cyl bore you are using.
The Corvette unit bearing hub fixes the knock back problem (in front). Using it on the CPP spindle allows everything to bolt up. The CPP spindle does not have a turn stop on it to limit turn angle, but neither do other aftermarket spindles.
You would have to use a tall ball joint to see any geometry improvement.
ATS makes a nice spindle that is forged Aluminum with 1" drop plus it's taller to fix camber gain. http://www.speedtechperformance.com/...rod/prd279.htm
If you are on a tight budget, then look at floating calipers using corvette rotors on a stock spindle, then add a tall upper ball joint.
The CPP is middle ground and needed if you go with manual brakes and/or 6 piston fixed calipers.
The ATS spindle is top of the heap so to speak.
http://www.PozziRacing.com
Old 01-06-2015, 03:53 PM
Blake Foster's Avatar
That is an interesting comment. I am sure JSM would have some CRAZY long winded explanation about this as he touted these as the ABSOLUTE best thing going. and has always slagged on the hubs used by GM and ATS.
Blake Foster
Old 01-06-2015, 05:55 PM
Old 01-06-2015, 08:28 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Smile
Hi Blake!
Here is a pic of Mr. Pozzi's experience pushing your AFX spindle/hub... If I recall David had approx.. 3/8" static clearance and upon hard cornering this was the result.....
[IMG][/IMG]
And then there was the ONE time/event that David/Mary ran the GMR hub that they took first place in Del Mar on the Auto-X. I don't recall any shavings
I would like to also ad (and hopefully David will verify), that he really spent no time working with myself to resolve the minimal "play" he was experiencing. (actually, if I searched hard enough I am sure I could find the email from him stating that....) Also, was about the time Art Morrison caught wind that David was trying out a NEW CPP Upright along with GMR Hub and decided to offer up a complete new front clip and was THE reason the CPP Upright and GMR Hub came off with no more testing...
So there you go Blake
The Following User Says Thank You to MillerBuilt For This Useful Post:
67XR7 (07-16-2020)
