Old 04-05-2016, 08:28 AM
Centerforce's Avatar
Centerforce Centerforce is offline
Originally Posted by Zspoiler View Post
I have run different clutches over time .And the one I have had the most luck with is a Center Force clutch with a steel flywheel.And I run this in my 1979 Z-28 RS Camaro Pro-touring car with a 500 HP plus Supercharged Small block Chevy.
Is it our Dual-Friction clutch that you are using, or a different model?
Old 04-28-2016, 08:46 PM
SlowProgress's Avatar
Default Dyad with the GM quick disconnect
Hello guys I started a thread a while back about clutch master connection to the Dyad clutch. I probably should have posted it in a different location. I noticed the centerforce guys are on here so maybe you could take a peak at the link and post up some information on the best way to reuse the GM quick disconnects (GM or DSE style clutch master) with the Ford style release cylinder recommended with the Dyad. It would be greatly appreciated.
The original dead end thread is below. Mods you can move this if I totally missed the mark.
https://lateral-g.net/forums/show...534#post636534
Thanks,
Old 04-28-2016, 09:06 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Its a Centerforce dual friction clutch.And I Heim -jointed my factory clutch likage so its extra smooth.
Old 04-29-2016, 08:07 AM
clill's Avatar
clill clill is offline
DYAD setup in Hellfire
Old 04-30-2016, 11:57 AM
Thanks a bunch Charlie. That's a great view of the coupler. I think that is probably how I will try to do it.
