Old 05-10-2016, 02:42 PM
Shiner's Avatar
Shiner Shiner is offline
Default 70 Chevelle Wheels and Tires- Stressful
I sound spoiled saying this but ordering custom wheels and tires is stressful.
I have ordered my Weld RT-S Wheels and I did this based on a combination of recommendation from Weld and research.
I have ordered
Front: 18x8 4.7BS and 275/40R18
Note: I now want to change this to 18x9 5.2BS and 275/40R18
Rear 18x10 6.2BS and 305/35R18
I am concerned that the wheels wont fit. I have ordered a Percys Wheelrite, however, I believe Weld is backed up right now due to a problem with their ovens on the RT-S line; So I suppose I have a window. The issue is the Percy's tool makes you bend a wire over the tires you want to use... Well I don't have the fronts yet to so something like that and mimic section width.
Do you guys think I should proceed and relax or what? Should I change the wheel size to a 18x9 in the fronts or get a smaller tire and run the 8s?
Talk some sense back into me.
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 05-21-2016, 11:21 PM
Zoomin Zoomin is offline
Lol! You're not the only one that wrestles with stuff like this. I struggled with the same thing after ordering 8", I had this nagging feeling I should've gone with 9's. I kept mulling it over and after 4 weeks I called and changed it to 9's.
When you're spending this much money, get what you want because do-overs are painful.
1964 Lemans
1966 Skylark
1969 Camaro
Old 05-25-2016, 12:32 PM
pro66tour's Avatar
pro66tour pro66tour is offline
Travis, I agree with Zoomin - It's personal (as is colour choice) and with the kind of cash being spent, what's a few extra bucks for what you want. Check out my thread, last few pages - a ground shot that captures what 18x8 and 18x10 (5.75 bs) looks like with a 295 tire. In my case was happy to get them used with the specs that they are. Would I go 18x9 front if I were to order - sure! I find it still looks great though. If these are around in the next 4-5 years when comes my car's time to blast and paint I will pick these up http://www.autoanything.com/wheels-r...t-s-s77-wheels Hope that sheds some light.
Old 05-25-2016, 03:08 PM
barrrf's Avatar
barrrf barrrf is offline
I had 18x8 in front and I hated the way it looked. I didnt have the luxury of being able to change it up without ordering new wheels - so I ordered new wheels and went up to 18x9.5 Im a wider is better type of guy tho.
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 05-31-2016, 12:13 PM
Shiner's Avatar
Thanks for the advice. Weld recommended that I just stuck with the 18x8 and 18x10 as this is the recommended size for the Chevelle. They state if they dont work out, i could return/exchange them. However, he said If I went with a wider wheel up front and it didnt work out- it would be my loss.
I went the safe route.
1970 Chevelle SS
Old 06-01-2016, 09:03 AM
barrrf's Avatar
Interesting. Im running 9.5s with zero clearance issues.
You could always get the wheel fitment tool and figure out what you need that way.
Old 06-01-2016, 01:50 PM
Blake Foster's Avatar
We did a 70 with the following
18 x 10 with 5.5 bs running a 315 up front (trimming of the outer wheel lip is required
18 x 11 with 6.5 bs and a 315 in the rear.
Blake Foster
www.speedtechperformance.com
Old 06-02-2016, 12:16 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
My wheels are larger and taller than anyone has mentioned on here and I don't have any issue with clearance, etc. I'm running a 20x9 up front and it turns normal without any rubbing whatsoever. I think you would have been safe with the 9" wheel.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-02-2016, 01:56 PM
jeff71 jeff71 is offline
Hey Blake have any high res pics you can post?
Old 06-02-2016, 04:47 PM
Che70velle's Avatar
Agreed. Front control arms play a huge role here. With stock arms, forget it. I had CPP on the front of my car that limited how much backspace I could run. They were similar to stock arms, but not as restrictive. With my new Global West front arms, I have no restrictions with back spacing. I have an 8" front wheel, but I can FOR SURE go in another 1.5", and still not hit frame, sway bar, etc.
Thanks Dad!!
