Old 07-21-2016, 01:13 PM
ma73z's Avatar
ma73z ma73z is offline
Very nice! Subscribed.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 07-23-2016, 03:37 PM
Goosesdad's Avatar
Originally Posted by pro66tour View Post
I agree - looks fantastic!
Originally Posted by classiccamaro View Post
Nice Job - Great Craftsmanship! Love the color....
Thanks guys!! Appreciate the encouragement, means a lot considering the company I'm in here!
Have a great day!
John
My Build Thread:
Old 07-23-2016, 03:51 PM
Goosesdad's Avatar
Wheels arrived this week, going through mock up now. With the 315's in the front, I knew I was headed towards flaring the front fenders a bit. Looks like the front track width is going to be a little over 2" wider than the rear so I am likely headed towards flaring the rears as well so I can push the rears out to be equal with the front???. Haven't ordered the rear-end yet so at least if I decide to flare the rear, that won't be an issue. Appreciate any advice on the track width issue.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
syborg tt (12-28-2020)
  #24
Old 07-23-2016, 04:42 PM
glassman's Avatar
glassman glassman is offline
Don't know how I missed this before. Nice job, love the little "unseen" details in the tranny tunnel. Plus, I'm a little partial to 2nd gens....
Mike
Old 07-24-2016, 05:08 PM
grendel grendel is offline
Having flared the tail end out with some metal work...
GO AS WIDE AS YOU CAN
Loving the work.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 08-07-2016, 10:11 PM
Goosesdad's Avatar
Loving the work.
Thanks. You and Steve both convinced me to flare the rear. Both of your cars look great. Looks like I will need to push the rear fenders out 1 5/8" each.
Have a great day!
John
My Build Thread:
Old 08-07-2016, 10:13 PM
Goosesdad's Avatar
Thank you!!
Have a great day!
John
My Build Thread:
Old 08-07-2016, 10:39 PM
Goosesdad's Avatar
Worked on the cowl this weekend, the plan is to seal it off 100%. Though I did prep the underside so it is sealed and could get wet if the access panel leaks. I will also drain the pockets below the wipers that I have created. Pics on that later. For sure I have a few hours with the grinder on my plate tomorrow!!
Have a great day!
John
My Build Thread:
  #29
Old 08-07-2016, 10:42 PM
Goosesdad's Avatar
Brakes arrived. A little shipping snafu with the rotors....but Bear and Matt's Classic Bowties are both top shelf. Slotted only rotors on their way.
Have a great day!
John
My Build Thread:
  #30
Old 08-11-2016, 09:48 PM
Goosesdad's Avatar
Welds cleaned up on the cowl. I will put a gasket under the access panel with the goal of completely eliminating the chance for any water or debris to get into the area below the cowl and down into the door sills. I sealed the metal with rust restore and then painted it....just in case water ever gets past the access panel or the wipers. I realize I've created a pool for water where the wipers bolt to the cowl, I might create drains here with some metal and rubber tubes to direct the water out. A decision for later.
Have a great day!
John
My Build Thread:
