Old 10-15-2016, 06:15 AM
randy randy is offline
I used earl hoses.
Old 10-15-2016, 10:12 AM
dhutton dhutton is offline
Originally Posted by randy View Post
I used earl hoses.
If it is rubber it is pretty much guaranteed to turn to mush in a couple of years. That is why guys are using PTFE for fuel hoses.
Old 10-15-2016, 12:33 PM
mine are earl fuel hoses. You can see the hose here on the loop from one fuel rail to the other. Used the same hose from the hardline to the fuel rail and hardline to the gas tank.
https://www.facebook.com/photo.php?f...type=3&theater
Old 10-15-2016, 01:19 PM
Unless it's Teflon I am pretty sure it will break down. Not trying to pee in your cornflakes, just being honest. There are a lot of threads and at least one magazine article about this.
Old 10-15-2016, 01:55 PM
One thread here specifically mentions earls:
http://www.pro-touring.com/threads/6...ight=Fuel+hose
Old 10-15-2016, 04:34 PM
I am going to call summit racing Monday see what they say... also going to look for a Ptfe version of the Russell one I bought ..
Old 10-15-2016, 05:05 PM
https://www.holley.com/products/plum...arts/350006ERL
That is what I used. Out of all the cars at the shop none of them have had issues
Old 10-16-2016, 04:24 AM
Thanks ... for perspective I am using Ptfe from pump to the front... my Ptfe ends at a bulkhead connection close to the engine... so this length of hose will either be a few inches... from fitting to end of intake ....of a few feet from fitting to fender mounted bulkhead
Old 10-16-2016, 11:06 PM
Ghiaguy's Avatar
Ghiaguy Ghiaguy is offline
I HIGHLY recommend Bonaco -- http://www.bonacoinc.com/ -- They have everything!!!! And everything they have is top quality!!!! Call the guys up and tell them your problem and they will help you out!!
Their tool for flaring steel/Aluminum lines for AN is world class too!!!
Old 10-17-2016, 05:27 AM
dontlifttoshift's Avatar
Here is the hose I use for fuel. I don't care for the braided teflon hose.
http://www.phenixindustries.com/prod...ss-inner-hose/
The information is sparse on the website but it is made of Viton and engineered for E85 so the ethanol in gasoline will not break it down.
Donny
