Old 03-25-2018, 01:29 PM
Timberline's Avatar
Timberline Timberline is offline
Default LS3 Crate harness question
I have a dumb question but her it goes where does the “Bulkhead” connector plug into?
Jeff
66 Nova Sport Coupe
Detroit Speed equipped front and rear
LS3 525hp, t-56 6spd
Build in progress
Old 03-25-2018, 01:33 PM
Oleyellar Oleyellar is offline
Default Nuthin'
Nothing unless you want to use it for instrumentation outputs. In the instructions there is a table of the outputs available to use.
Old 03-25-2018, 01:47 PM
Timberline's Avatar
Smile
Thank Oleyeller
Jeff
66 Nova Sport Coupe
Build in progress
Old 03-25-2018, 02:18 PM
130fe 130fe is offline
Thumbs up
Jeff, do you have the instructions? If not I can email you the PDF.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-25-2018, 03:27 PM
dhutton dhutton is offline
Bulkhead connector also connects to the auto transmission controller if you have one.
Old 03-26-2018, 09:52 PM
randy randy is offline
I pulled ignition and speedometer off of it.
Old 03-27-2018, 09:15 AM
samckitt's Avatar
samckitt samckitt is offline
Pinout & part numbers in attached PDF.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-30-2018, 10:26 PM
Timberline's Avatar
Thanks everyone for your help !
Jeff
66 Nova Sport Coupe
Build in progress
Old 04-28-2018, 12:02 PM
Timberline's Avatar
For those that have used the bulkhead what’s the best way to pin it and what type pin does it use male or female etc.. ?
Not sure how the purple connector comes apart... figured I would ask before I break it ...lol.
Jeff
66 Nova Sport Coupe
Build in progress
Old 04-30-2018, 08:22 PM
samckitt's Avatar
Scot
86 Monte SS
LS2/T56 Magnum
