Old 07-23-2020, 08:14 PM
tdishon tdishon is offline
Getting bed floor situated. Need a 4" floor lift and decided to have a tilt up floor.
I had my old tailgate and thought the script would look good on the back of the floor lift.
The Following 2 Users Say Thank You to tdishon For This Useful Post:
camcojb (07-24-2020), dhutton (07-24-2020)
  #62
Old 07-24-2020, 02:10 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Nice little touch with the Chevy script on the bed floor when you let the tailgate down. I like it...
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-24-2020, 06:41 PM
Agreed. The script is a great idea. What's the purpose behind a tilt up floor? Having storage underneath?
Old 07-24-2020, 07:32 PM
I wanted a tilt up bed floor to access the transmission(it's in the rear). Also, I need to remove the top shock mount to take the rear tires off. I might as well have the fuel fill under the bed(still undecided). But the battery will be under the tilt bed for sure. All in all, just for easy access to everything. It does make changing the tire cake.
Old 07-25-2020, 07:37 AM
streetbird's Avatar
streetbird streetbird is offline
Pretty nice built
The French Frog
Old 07-25-2020, 12:15 PM
ScotI ScotI is offline
I'm setting the floor up on my patina 64swb in a similar fashion (center wood between the tubs will be hinged). Easier access to the exhaust, batt, shock mounts, gas tank components, & differential if needed.
I know on mine, rear tire changes are still going to be a fuss....
Old 08-01-2020, 02:45 PM
Bed floor coming together.
camcojb (08-01-2020), Goosesdad (08-02-2020)
  #68
Old 08-01-2020, 04:31 PM
dhutton dhutton is offline
Looks great.
Old 08-22-2020, 06:36 PM
Tilt bed framing done and working. I have several rubber adjusters in several places that keep all squeeks away.
The Following 5 Users Say Thank You to tdishon For This Useful Post:
camcojb (08-22-2020), dhutton (08-22-2020), EVIL SS (08-23-2020), jarhead (08-22-2020), WILWAXU (08-23-2020)
  #70
Old 08-23-2020, 03:12 PM
Nice work on the bed! Will you keep it as a wood bed?
