Old 12-21-2020, 12:40 PM
Jr's Avatar
Jr Jr is offline
Originally Posted by CarlC View Post
One of the challenges of having a not-driven-often car and using a complete system disconnect switch is that the long and short fuel trims get deleted once power to the ECM is disconnected. Not a big deal, but it may mean the car is a bit "cranky" until 1-2 cold start and run cycles are complete.
I use a disconnect switch to disconnect the main power buss but have a simple 5A circuit breaker bypass in order to protect the whole system when in storage. A battery maintainer is easy enough to do.
Yes, I’m definitely going to hook a disconnect up.
Old 12-21-2020, 03:15 PM
Musclerodz's Avatar
toss the red top, and change to yellow. Once a redtop discharges, its done. Doesn't solve your problem, but its the first thing I would do. I won't run redtops anymore
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-21-2020, 03:44 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
I had this problem on my 1981 El Camino SS .The shop found a short under the drivers side power seat .I disconnected it and have had an issue since ,Maybe you have a similar problem .Good luck on your search.
The Following User Says Thank You to Zspoiler For This Useful Post:
orangevert (05-04-2021)
  #14
Old 12-21-2020, 04:59 PM
dhutton dhutton is online now
Originally Posted by Jr View Post
Dead/discharged not damaged. This is the 4th optima I’ve put into the car in 4 years.
So you are able to charge the battery after it is discharged?
Old 12-21-2020, 05:01 PM
Even an Optima charger can’t bring it back?
I run Odyssey and I’m able to bring them back with an Odyssey charger.
Old 12-21-2020, 05:24 PM
Jr's Avatar
Jr Jr is offline
No. When it’s discharged, it’s done.
Old 12-21-2020, 06:38 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
A conventional charger definitely cannot bring them back. A pulse charger can in many cases. I have done it myself. Again check out the R2 battery saver chargers and videos I posted. Not pushing them as a brand but the videos are loaded with good information on the technology.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 12-22-2020, 04:24 AM
What charger are you using?
Old 12-22-2020, 06:21 AM
Jr's Avatar
Jr Jr is offline
Battery tender.
Old 12-22-2020, 06:23 AM
Jr's Avatar
Jr Jr is offline
Thank you. Yes, there is some great info in these videos.
