Old 12-20-2020, 12:02 PM
Jr's Avatar
Jr Jr is offline
Default I keep killing optima red top batteries
Hi guys,
I need help figuring out how/why I keep killing optimas.
The car:
1967 Camaro
New aaw wiring
Ls with lsa blower.
Bosch intercooler pump. Pump stops working when key is off.
Anvil light bar headlights
Holley dash/ dominator ecu
Vaporworx fuel module
Zl1 pump.
Where should I start looking? Could it be a bad ground? Is something still “on” even though the key is off?
Jr
Old 12-20-2020, 01:46 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Originally Posted by Jr View Post
Hi guys,
The car:
1967 Camaro
New aaw wiring
Ls with lsa blower.
Zl1 pump.
Jr
Have you tested for parasitic battery drain?
https://www.youtube.com/watch?v=zdIKNnwEjIs
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
Old 12-20-2020, 04:28 PM
Jr's Avatar
Jr Jr is offline
No, but I will.
Old 12-20-2020, 06:24 PM
morrisclassic morrisclassic is offline
Lateral-G Supporting Vendor
Default battery drain
cjfirstgen is giving good info.
I had the parasitic drain problem on my 69 Camaro,
finally found it of all things the clock in the stereo!!
It took a while for the battery to drain but over time
setting in the garage the car wouldn't't crank.
Billy
Old 12-21-2020, 05:58 AM
dhutton dhutton is offline
Define killing. Is it discharged or is it damaged and not chargeable?
Are you using the correct charger for Optima batteries?
Don
Old 12-21-2020, 08:10 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
Cjfirstgen is giving good info.
Parasitic drain.
I had the same exact problem on my 68 Camaro and found two leaks from my fuel injection and transmission computers. Since both loads have to bypass my disconnect switch and go directly to the lead of the battery, I decided to change out my red top Optima and install an Odyssey battery.
Problem solved. Odyssey batteries rule!
Old 12-21-2020, 08:28 AM
cjfirstgen's Avatar
That is the biggest issue with the modern ECU's and electronics we have put into classic cars. Most new cars have some small amount of parasitic drain but in theory they get driven regularly where our classic cars do not. A battery maintainer is pretty much a necessity. You can also utilize a battery disconnect which I recommend.
Not all maintainers or chargers are created equally. I use R2's for their digital readout but CTEK and others use the same pulse type charging technology aka (smart chargers). Learn about the difference here.
https://www.r2batterysaver.com/batte...earch-summary/
https://www.r2batterysaver.com/produ...attery-rescue/
The Following User Says Thank You to cjfirstgen For This Useful Post:
Spiffav8 (12-21-2020)
Old 12-21-2020, 10:34 AM
CarlC CarlC is offline
One of the challenges of having a not-driven-often car and using a complete system disconnect switch is that the long and short fuel trims get deleted once power to the ECM is disconnected. Not a big deal, but it may mean the car is a bit "cranky" until 1-2 cold start and run cycles are complete.
I use a disconnect switch to disconnect the main power buss but have a simple 5A circuit breaker bypass in order to protect the whole system when in storage. A battery maintainer is easy enough to do.
http:www.vaporworx.com
The Following User Says Thank You to CarlC For This Useful Post:
syborg tt (12-29-2020)
Old 12-21-2020, 12:36 PM
Jr's Avatar
Jr Jr is offline
I usually have the battery connected to a battery tender. I was looking at the optima 400 and 1200 series.
I will look into the ctek maintainer.
Old 12-21-2020, 12:39 PM
Jr's Avatar
Jr Jr is offline
Don
Dead/discharged not damaged. This is the 4th optima I’ve put into the car in 4 years.
