Old 10-08-2007, 07:52 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Default 6 speed behind a 455 poncho help.
I may have asked before, but does anyone here have a source for a bellhousing to bolt to a 455 or any pontiac block so I can run a 6 speed behind it? I have tried Weir products but he is "in casting mode", so no luck. Any other suggestions? The 6 speed is from a 2002 Z-28.
Thanks in advance.
Jim
Old 10-08-2007, 09:18 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Call McLeod's tech line. Their modular bellhousing should do it.
Old 10-08-2007, 09:21 PM
chicane's Avatar
chicane chicane is offline
McLeod modular bellhousing P/N: 8710-10 // http://www.mcleodind.com/application...L_HOUSING.html
Pictured at the bottom of this page: http://www.mcleodind.com/downloads/p...DFs/Page_9.pdf
Old 10-08-2007, 11:14 PM
COYBILT's Avatar
COYBILT COYBILT is offline
the mcleod bell housing should be the ticket on this one.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 10-09-2007, 05:29 AM
Ummgawa's Avatar
Most excellent, Thanks!!
Jim
Old 10-09-2007, 06:05 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
With the mcleod bell housing do you use a mechanical linkage or the LS1 Camaro hydraulics?
Old 10-09-2007, 06:38 AM
Mkelcy's Avatar
If you swap out the "front intermediate plate" (that's what Tremec calls it) on the T56, you can use a mechanical linkage with the modular bellhousing. The substitute intermediate plate has a provision for a clutch fork pivot. If you don't do the swap, you use the LS1 hydraulic linkage. McLeod manufactures and sells intermediate plates - about $320 through Summit.
