Old 01-08-2008, 02:23 AM
Default Who has speartech LS7 harness ?
If somebody have speartechs LS7 harness , could i have the OD diameter of the main harness - where it goes thru firewall ??
Thanks!!
63 Z06
Old 01-08-2008, 05:40 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Off the top of my head, it's about an inch in diameter. However, some of the connectors, like for the knock sensors, are larger than that. If you plan on only cutting a 1" hole in the firewall, you'll have to remove the wires from the plugs then reassemble them.
My LS7 69 Camaro
Old 01-08-2008, 11:41 AM
Thanks again Scott for help. I am going to use same "seals it" split seal as did Joe in here:
https://lateral-g.net/forums/show...t=12451&page=2
Now i can order the seal allready and fab maunting plate same way as Joe.
Again, one thing solved
63 Z06
