Old 02-08-2008, 11:59 AM
DDY RCKT's Avatar
DDY RCKT DDY RCKT is offline
Default Need help with tire sizes
Hey all! Hey guys, I've got a set of wheels I want to put on my 02 Z06, and they're not stock size, so the tire size issue is once again going to be asked.
The new wheels are 18 x 8.5 in the Front and 19 x 10 in the rear.
Stock tire size is 265/40/17 front, 17x 9.5 wheel and 295/35/18 rear, 18x10.5 wheel.
So what tire width/aspect will keep me closest to stock, and still fit on the rim, and not be impossible to find. I feel like I can use a 295/30/19 on the rear just fine.
Can I use a 265/35/18 on the 8.5" fronts? Or do I need to step down to a 255/40/18?
2002 Corvette Z06
Old 02-08-2008, 12:51 PM
JohnC JohnC is offline
It maintains better overall height to prevent throwing your speedo too off and maintains almost identical side wall heights to your rear 295-30-19.
255-40-18 is too tall ( 0.68 inches taller)...
... and 265-35-18 may be a little too wide since you are going from a 9.5 width to a 8.5 width up front.
Lets see some pics when you get'em!
John
Old 02-08-2008, 02:09 PM
DDY RCKT's Avatar
Originally Posted by JohnC
255-35-18
John
Thanks, John! I'll definately have some pics up. They're really sweet wheels, too. GM Prototype wheels that may be the only set like them in existence. Probably no more than 5 sets, if more than just the one were commissioned.
How far do you think it'll throw my speedo off?
2002 Corvette Z06
Old 02-09-2008, 06:55 AM
Not much at all (less than 1 mph) IF you use 255-35-18...
Old 02-09-2008, 09:41 AM
JayR JayR is offline
Lateral-G Supporting Vendor
And when in doubt use the tire size calculator!
http://www.rims-n-tires.com/rt_specs.jsp
Old 02-09-2008, 10:51 AM
Yep, this is the one I used for you...
http://www.discounttire.com/dtcs/infoTireMath.dos
John
Old 02-09-2008, 07:05 PM
DDY RCKT's Avatar
Clicked and favorited! Thanks guys!
Here's a pic of the wheels!
2002 Corvette Z06
Old 02-11-2008, 09:51 AM
Payton King's Avatar
Default Not sure of the back spacing on those
but the size is the same as for a C6 vette. 8.5x18 on front and 10x19 on rear.
The stock tires for a C6 are 245/35/18 and 285/30/19 rear.
Would you like to part with those? My 69 is running a set of C6 rims and tires and those would bolt right up...assuming they are prototype for the C6.
I know a C6 back spacing for the rear is different on a C5 as compared to a C6...
Did I mention that I would really like to have those on my car?
Old 02-11-2008, 12:46 PM
DDY RCKT's Avatar
My wheels!!!
Can I go with the 255F and 295R, you think? The tires I want, I can't get in a 285, so I kind o fneed the 295. I can run the 245 in the front, but if the 255 will work, I'd prefer those.
2002 Corvette Z06
Old 02-11-2008, 12:54 PM
255-35-18 front
285/30/19 rear
