Old 02-11-2008, 09:52 AM
rwhite692's Avatar
I went the "el-cheapo" route and used the Rust-Oluem brand two-component epoxy from home depot. It has been holding up surprisingly well so far. There are of course better coatings out there, but, for the money spent, I am extremely happy with it.
About the only thing that can scratch it is DRAGGING something heavy with metal casters (like a loaded engine stand) across it AND the caster gets crossed-up...and even then, it only scratches the surface but doesn't ever chip or come up off the floor...My floor was bare concrete from 1986 to present and had plenty of oil staining, etc. The rustoleum kit came with citric acid (in powder form which you mix w/water) to clean/etch the concrete. No matter which system you go with, preparation will play the biggest role in getting good adhesion....Here are a couple pics:
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 02-11-2008, 02:48 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I too went the cheap route and did it my self. Use the BEHR two part kit and then cleared over the top. Like the others have said it's a lot of prep time but worth it in the end. If I did it again I wouldn't use the flake.
Curtis
Old 02-14-2008, 12:03 PM
Hotrodrobert Hotrodrobert is offline
We had a professional clean the floors and install Behr Epoxy on our shop floors.
So far, we have discovered that welding splatter doesn't seem to bother the coating very much. Water doesn't bother it much either.
ANYTHING ELSE WILL REMOVE IT WITH EASE
When we complained, we were told not to get those things on the floor-antifreeze, gas, oil, atf, brake fluid............
Old 02-14-2008, 06:12 PM
jbutlr's Avatar
jbutlr jbutlr is offline
if you have a new house or a freshly poured slab wait at least a year before you coat it. It takes awhile for all the moisture to work it way out of a slab that is not exposed to any direct sun light.
Old 02-17-2008, 11:52 AM
Steve1968LS2's Avatar
Why would those things be in a garage anyways???
