Old 07-03-2008, 11:01 AM
Blake Foster's Avatar
Default where to find a pitman arm
Wow who would have guessed it would be impossible to find
i need a pitman arm for a 78 Trans Am, i got one from a 79 Camaro and it is 1.5" too long.
any ideas?
Blake Foster
www.speedtechperformance.com
Old 07-03-2008, 01:01 PM
PRRC PRRC is offline
Try Borgeson. They may be able to help.
Tim
www.paradise-road.com
Old 07-03-2008, 01:52 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Would this work?
http://cgi.ebay.com/ebaymotors/TRANS...spagenameZWDVW
Old 07-05-2008, 08:36 PM
David Pozzi's Avatar
any ideas?
Blake, Longer is better! I'd use the 79 Camaro pitman.
David
http://www.PozziRacing.com
Old 07-05-2008, 10:48 PM
The problem with it being longer is that the idler is then not the same length and the inner tie rod ends hit the frame when turning so i need to find the original that is 6" center to center
Blake Foster
Old 07-06-2008, 07:55 PM
I see.
Old 07-06-2008, 09:05 PM
class67's Avatar
class67 class67 is offline
Try this!
http://www.rareparts.com/partslist.html
Steve
67 Camaro RS
66 Chevelle (in progress)
Old 07-07-2008, 03:42 PM
Strike 3
the issue seems to be that it is a nonwear part. so who out there has a pitman arm there not using???
Blake Foster
Old 07-07-2008, 04:11 PM
Cread01 Cread01 is offline
I am not sure if the camaro and trans am are same but I am changing my steering box to an agr box and i have a new pitman arm with the box. So you may be able to get one from agr. otherwise I will have the one from my 78 camaro in a couple weeks.
Old 07-07-2008, 08:50 PM
thanks ill check with AGR
Blake Foster
