Old 01-17-2009, 12:43 PM
67rstbkt 67rstbkt is offline
Default semi-smooth firewall?
I want to partially smooth out the sheet metal transition on my 67 firebird and was wondering if it would be o.k to use a metal based body filler instead of seam sealer and smooth out the transition. I'm not looking for a completely smooth firewall look; just factory with a little flair. Is this a good option?
Thanks; I'll post some pics of my progress later.
Old 01-17-2009, 03:04 PM
elitecustombody's Avatar
if there is a seam,it will have to be welded and ground smooth before any filler can be applied or you will be taking a chance on filler cracking
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 01-17-2009, 03:26 PM
Got it; so weld it up, grind smooth, then use metal based filler
Old 01-17-2009, 10:15 PM
yep that's the way to do it, if you're patient enough you can weld and smooth out the welds to where you won't need any filler,but it takes time
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 01-18-2009, 01:31 AM
G-Body's Avatar
G-Body G-Body is offline
I just did a little work on my smooth firewall today heres a few photos!
Old 01-23-2009, 12:55 PM
peetsjunkie peetsjunkie is offline
same here.. I had some issues on mine though...had to cut out smaller patch due to warpage.
