Old 11-22-2005, 08:13 AM
tndude tndude is offline
Talking My Big Bad Rotisserie
gone ...
Old 11-22-2005, 08:16 AM
hotwheels's Avatar
hotwheels hotwheels is offline
wow, that thing will be nice to have when it's done..........do post up some pic's.......will be kewl to see.
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 11-22-2005, 08:42 AM
907rs's Avatar
907rs 907rs is offline
That's beefy, Doug. I don't think the Chevelle will be a problem.
Bill
Old 11-22-2005, 08:48 AM
Yea, I wanted to be sure I ordered the right strength hand winches to lift the car. I don't want the cable to give while I'm under it....I ordered two with weight limit of 2000 lbs strength each.
Here is what it is suppose to look like when its done. This is a pic of Troy Trepaniers' (Rad Rides by Troy) rotisserie.
Old 11-22-2005, 09:09 AM
68protouring454's Avatar
Default jacks
why not use hydraulic bottle jacks, way safer then winches and works nicer too, here is a pic. this is a buddies andn i copied his and made one myself, pics of mine are too big to post.
jake
Old 11-22-2005, 09:22 AM
jake
Wow Jake, thats a big'n also. Looks like you could do that school bus with that one. Hydraulic jacks are cool and I agree. Perhaps down the road I'll add them. For now, I'm trying to keep my cost down due to the fact this stuff keeps adding up.
Old 11-22-2005, 12:28 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Looks pretty stout, Doug. If it's good for Troy it's good for us.
My LS7 69 Camaro
Old 11-22-2005, 02:51 PM
Default jacks
those jacks are 30 or so bucks at harbor freight, not sure what your paying for the winch but it cannot be too much cheaper, check them out, i can give you measurements etc
jake
Old 11-22-2005, 06:16 PM
oldzzy's Avatar
oldzzy oldzzy is offline
I found that if you put the pieces that join the two ends of the rotisserie together on the outside rather than in the middle it gives you alot more room if height is an issue. Also jacks on both ends is a great feature that you will be glad you added.
Shane
70 Olds W31 clone
http://www.flickr.com/photos/85638053@N00/
Old 11-23-2005, 12:51 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
Can you post a list of the parts to build one like that. I think that would work perfectly for me .
David
P.S. Here is ONE I found, but it does not appear to have a winch or jack.
