Old 05-05-2010, 08:54 AM
427gt500E 427gt500E is offline
Looks good Rusty.Where's the car going when finished and what are the plans of the owner?
Old 05-05-2010, 11:07 AM
GPR's Avatar
GPR GPR is offline
At this time we are doing the rust repair, remove drip rails and add fender flares and get it in prime. The owner is not sure where he will be stationed after Iraq so I'm not sure if we will be painting it.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 05-06-2010, 07:08 PM
GPR's Avatar
GPR GPR is offline
Brian cut the floor out next step will be subframe connectors.
Rusty Gillis
Port Richey Fl
Old 05-10-2010, 05:51 PM
GPR's Avatar
GPR GPR is offline
This afternoon Brian starting making the right subframe connector. Since the early Mustang has no torque box in the front we are making one out of 2 x 2 and also welding it to the rocker and the rear torque box. He still has to finish welding it to the rocker
Rusty Gillis
Port Richey Fl
Old 05-10-2010, 07:50 PM
Dougs67camaro's Avatar
Dougs67camaro Dougs67camaro is offline
Nice work your doing there! I miss my 66 fastback!
Old 05-11-2010, 12:33 PM
GPR's Avatar
GPR GPR is offline
Brian finished welding the rocker and added the top of the rear torque box
Rusty Gillis
Port Richey Fl
Old 05-11-2010, 01:10 PM
Nice work that should make a big difference.
Old 05-26-2010, 10:53 AM
GPR's Avatar
GPR GPR is offline
The floor is finished and epoxy primed
Rusty Gillis
Port Richey Fl
Old 11-15-2010, 06:49 PM
GPR's Avatar
GPR GPR is offline
It has been awhile since we have worked on this project we have been working on a couple of other projects but it is time to start working on the 65 Fastback.
This is what we found under the cowl panel
After the lower cowl panel is removed
The dash also has rust and was removed
Rusty Gillis
Port Richey Fl
Old 11-16-2010, 08:15 AM
The floor looks great. Theres allway surpises on these projects.Nice work.
