Old 06-14-2010, 10:37 AM
elitecustombody's Avatar
Originally Posted by CraigMorrison View Post
We didn't do 1/4 mile tests as ElToro isn't really set up to do that and were more interested in the skidpad and slalom testing. Matt (Silver69Camaro) is the owner of the car and has put a lot of miles on both suspensions whild driving it on the street so he should be able to chime in on that.
I know one of his biggest complaints with the 3-link was the noise the spherical rod ends transmitted into the cabin of the car. We have sourced a new rod end that should cure this issue though......
Care to say who is the maker of the new rod ends?
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-14-2010, 02:48 PM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
We have them on the shelf and they are the same width as our Poly bushed rod end. Depending on what sort of brackets you have, the new rod ends may or may not be a direct drop in. Some dremel work may be needed.
Art Morrison Ent.
www.artmorrison.com
Old 06-14-2010, 04:43 PM
For the life of me I couldn't find a 4-link setup on your website offered for sale
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 06-14-2010, 05:58 PM
dhutton dhutton is online now
If you download the catalog from their website the Camaro rear clips are in there.
Old 06-14-2010, 07:45 PM
tried, no workie
Old 06-15-2010, 06:03 AM
davey davey is offline
Default 4 Link Angles
Can you please tell us what the angles are of upper and lower control arms in the 4-link?
Old 06-15-2010, 06:32 AM
Are you guys asking about a four link or triangulated 4-bar? Are you doing an install on a stock chassis / unibody or building your own thing? Or are you just looking for the optimum angles and trying to get close?
Art Morrison Ent.
www.artmorrison.com
Old 06-15-2010, 07:55 AM
Silver69Camaro Silver69Camaro is offline
Originally Posted by Nutsy View Post
That is a great test! And congratulations on the superb number!
Have you guys done any 1/4 mile comparisons?
What about street driving comparisons?
Does 1 stand out over the other in these scenarios?
Both suspensions feel pretty much the same on the street. If anything, the 3-link may have a tad more foward bite due to a slightly shorter IC. The 3-link feels razor sharp when using spherical rod ends though - but very very noisy.
Performance and packaging combined, the triangulated 4-bar really shines.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 06-15-2010, 09:08 AM
I finally got the catalog downloaded,for some reason it didn't want to work on my wife's laptop,
I have a question for you guys, why is it that only one end of the links has adjustable end? Why not both ends? Is it to keep the costs down? I'm on a fence ,hesitant to pull the trigger and can't decide if I should build my own tri 4-link with currie end or buy yours,the only problem I see ,is that I want fully adjustable ends, so if I have to tweak something ,I won't have to pull the arms out of brackets to do a simple adjustment,is there an option for both ends of the bar to be adjustable?Can any of you give me a good answer, Matt, Craig?
Also a quick question, your tri 4-bar kit, is it universal or made for 1st gen F body?
Thanks alot
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 06-15-2010, 09:40 AM
Typically we offer four-bar/link type suspensions with one fixed bushing because they are more sucesptable to a jam nut backing off while the axle housing articulates. Granted, this usually only occurs in drag-race four-link suspensions. It's also cheaper for the customer to have one fixed end on each link.
I don't see any reason why we couldn't do it with LH/RH threaded links, but it may cost a bit more (more rod ends, custom links, blah blah). I can look into it if you'd like.
The tri 4-bar kit is strictly universal.
Matt Jones
Mechanical Engineer
