Old 06-29-2010, 11:49 AM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
Originally Posted by pro-tour79 View Post
lets not create problems that don't exist to promote a product please, if aluminum corrosion is such a problem we all better quit the hobby.
Poly body bushing don't squeak, there are no moving parts.
But you could say the Delrin is not the right material as it absorbs moisture and cause corrosion of the frame and floor pan.
Whoaa...easy. Nobody is creating non-existing problems. We all know that we have to polish our wheels to keep them from corroding and that is an acceptable trade-off we understand and are willing to accept. What a lot of people don't know is that aluminum against steel has an electrolytic effect that causes corrosion. Additionally it's a product mounted under the car, subjected to the worst environment, and typically forgotten about once installed. Is a little corrosion a huge problem? Maybe not but the fact that Delrin does not corrode IS a selling feature worthy of mentioning in a press release. I think if someone was looking to purchase an item (such as the OP) most would want to know the pro's and con's of each option...
Brett
WWW.BMRSUSPENSION.COM
