Old 07-03-2010, 04:57 AM
bulldog19 bulldog19 is online now
Default Rear Tire Rub
I have 68 Camaro Convertible Hotchkis TVSS suspension and the rear tires rub the fender lips when going over the slighest bump/dip in the road @ speed. Tire/wheel combo is 17" rim with 285/40 tire. I have roughly 3/4" space between top of tire and fender trim. I have a decent sound system in trunk, 2-10" subs and an amp which i know has led to this problem.
Future plans include going to 18" rim/tire but that's not for another year or so till I can save the $$ to do so.
Front i have no issues combo is 235/40 on 17" gap there is about 1-3/4" but i would like to lower here. Suggestions? Car has been done over a year and i have about 1500 miles on it so I thhink I have experienced all the settling that will happen.
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 07-03-2010, 06:14 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I don't think there's much you can do.
Some wheels have a thick mounting pad that can be milled slightly for more backspacing, which would get the tire further away from the quarter. But if the tire is near the wheel house, that's not going to be an option either.
What wheels are they, and how far is the tire from the wheel house?
Old 07-03-2010, 10:02 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Like Mark said, You cam mill a little off the mounting pad but a 10 with a 285 is maxing out a Camaro wheelwell. See where it's rubbing and if you can do any rolling or trimming and seriously consider going down to a 275 which may be all you need since you don't usually see a 285 in a 1st gen.
Old 07-03-2010, 01:36 PM
A 285 on a 10 is too big
Echo, echo, echo
Frank Serafine
Old 07-03-2010, 06:39 PM
Echo, echo, echo
Shoulda called you first huh Frank!
Old 07-03-2010, 09:31 PM
JRouche JRouche is offline
Echo, echo, echo
HUH?? You mean a 285 on the stock camaro is too big right? Cause a 285 is perfect for a ten inch wheel. Its the measured rim width for many 285/40/17 tires.
My 285/40/17 GY F1 GS-D3 on 10" rims. JR
Old 07-04-2010, 12:05 AM
Yes, 285 on a 10 is the right size but is too bog for the car. I have pulled it off BARELY on a 9.5
Frank Serafine
Old 07-04-2010, 07:18 AM
dhutton dhutton is offline
I have a 275 on 10 inch rim on my 69. The backspacing is 5.9 inches It is tight and I had to do some trimming of the wheel opening. If your rear end is even slightly off center it will rub worse. I ended up adding a 1/8 spacer on one side because it was rubbing a little on the inside.
Old 07-04-2010, 09:27 AM
No big Loss here, I bought them as a set 3-years ago for $1200, sold them last night for $1000. Rather than buying 2-New tires I just decided, with my wifes urging, to just bite the bullet and go for some new rims and tires. I searched last night and came up with these choices:
Boze Lateral-G http://www.zeforged.com/lateralg.html
Boze Injected http://www.zeforged.com/injected.html
Rushforth Livewires
It's a black convertible, black top. I don't want the exposed hardware and unsure as to finish on the spokes. Brushed Center? Powder Coated Color? Full Polish?
Thanks for any Input, Opinions, suggestions are welcome.
18" or 17" ?
John
Old 07-04-2010, 10:09 AM
melman109's Avatar
melman109 melman109 is offline
polished livewires! Car looks sweet btw
Mel
80'z Performance LLC
1965 SS Malibu
1968 SS Camaro
1970 Chevelle
