Old 07-16-2010, 10:33 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default Ny-Trex Nitrous Systems
Ny-Trex Bare-Bones Nitrous Systems
http://www.xplosiveperformance.com/N...s-_p_1787.html
Bare-Bones Nitrous Systems use top quality components with an emphasis on performance and price. These Ny-Trex Systems have many of the great features offered in our top line systems and have been thoroughly dyno-tested on numerous vehicles to insure the most safe and reliable performance possible at any price.
Bare-Bones EFI Economy Wet Nitrous System uses the Raptor wet Nozzle (up to 175hp)
Bare-Bones Economy Carb Plate System uses the Bare-Bones 4150 plate (up to 200hp)
Each Complete Bare Bones Systems Include:
Adjustable HP jetting
10 lb Wet-Black powder coated bottle
Hi-Flo 660 bottle valve
Bottle brackets
Braided stainless lines
Switch controls, clamps, fittings & hose
Brackets, hardware, bolts
Easy “Step-By-Step” instruction sheet
Lifetime Warranty on solenoids
Ny-Trex 8 cyl EFI Wet Nitrous Kit
http://www.xplosiveperformance.com/N...t-_p_1786.html
Ny-trex is proud to offer the all new EFI 4, 6 and 8 cylinder wet nitrous systems. Ny-Trex EFI wet nitrous systems use only the highest quality materials and components to produce the best performing, best looking and most
reliable wet system around.
Ny-Trex systems have been throughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible.
Complete Systems Include:
Chrome Hi-Flo 660 bottle valve with gauge port
Braided stainless N2O feed line w/Tefl on core
22”x-3 braided stainless nozzle lines, 1 blue, 1 red
T-Rex Nozzle* & adapter (up to 300+HP)
15A WOT micro switch
Quick-Clamp stainless bottle brackets
Mounting hardware, brackets, bolts, screws, clamps, ties
Electrical components, wire connectors, relays, switches
Drill & tap, fittings, sealant
Hot-Shot N2O & fuel valves
Lifetime warranty on solenoids
Special Features
Exclusive T-Rex Nozzle* with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering only 35 HP.
Nozzle has unique faceted spray tip to pass air around the nozzle without disrupting the spray pattern.
T-Rex is the highest fl owing nozzle available with .110 fuel and nitrous passages that can deliver over 300 hp with a single nozzle.
Flow matched fittings allow for the use of any style flare jets that are currently used in the industry.
Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts.
Plungers are made of high grade alloy with greater tolerances to prevent sticking. The N2O seal is Tefl on and a special Viton seal is used for fuel.
Dual Taper Jets provide a consistent fl ow of nitrous and fuel and come in a large array of sizes.
Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Tefl on sealant and easy install Quick-Guide.
Triple-Threat™ V-8 EFI Wet Nitrous System by Nytrex
http://www.xplosiveperformance.com/T...ex_p_1782.html
Ny-Trex is proud to introduce the next phase of nitrous innovation, the Triple-Threat™ wet nitrous system. This system combines all three valve functions: Purge, N20 and fuel in one easy to install component. The Triple-Threat™ is a precision machined billet body with three integral solenoid valves with Volt-Trap coils for a dependable, clean, all-in-one nitrous system.
Ny-Trex nitrous systems use only the highest quality materials and components to produce the best looking, best performing and most reliable wet system around. Ny-Trex exclusive Triple-Threat™ systems have been thoroughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible.
Liquid Filled Bottle Gauge
Fuel Pressure Safety Switch
Complete Purge System with V-Spray
Chrome 660 Hi-Flo valve with gauge port
Braided stainless N2O feed line w/Teflon core
T-Rex Nozzle & adapter (up to 300+HP)
Triple-Threat™ Valve w/Lifetime Warranty
Special Features
Exclusive T-Rex Nozzle with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering as low as 35 HP.
tolerances to prevent sticking. The N2O seal is Teflon and a special Viton seal is used for fuel.
Dual Taper Jets provide a consistent flow of nitrous and fuel and come in a large array of sizes.
For You Mustang Guys Check this beauty out
http://www.xplosiveperformance.com/T...em_p_1636.html
Call our TOLL FREE NUMBER or PM us for ADDITIONAL SAVINGS THIS MONTH
888.493.8041
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
