Old 01-12-2006, 03:44 AM
Default Biggest wheel/tire combo with DSE tubes and springs?
Hello!
I know this is an old subject but what is the really widest wheel wich can be used in 69 camaro with DSE tubes ,springs and offset kit ? I am intrested 18"-20" .
Old 01-12-2006, 05:37 AM
XcYZ's Avatar
XcYZ XcYZ is offline
If you plan on running leaf springs, then the largest would be a 335 on a 12" wheel. I don't see how you could get a 345 in there and not rub on the leaf spring or fender lip - unless you had more offset than what the DSE offset shackles use and move the front perch inward.
My LS7 69 Camaro
Old 01-12-2006, 06:15 AM
Thank you Scott!
Actually 335 would be fine but i was thinking of 13" wheel. But i want to stick in easy DSE products.
Do you know has anyone 335/19s ?
Thanks!
Old 01-12-2006, 07:06 AM
TravisB TravisB is offline
Originally Posted by Bowtieracing
Thank you Scott!
Thanks!
I think michelin has 19's......
Kenny Davis Hot Rods
Old 01-12-2006, 12:02 PM
345 / 20s are the same width as 335 / 18s
Old 01-12-2006, 12:29 PM
XcYZ's Avatar
I didn't know that.
I do know that Jody tried putting a 345/30/18 in his 69 that had the same rear setup as mine and it wouldn't fit - just not enough room between the leaf spring and the fender lip.
My LS7 69 Camaro
Old 01-12-2006, 12:38 PM
both with the same sidewalls or ?????
Old 01-12-2006, 07:27 PM
Here ya go
335/30/18
http://www.tirerack.com/tires/Spec.j...e1=yes&place=1
345/25/20
http://www.tirerack.com/tires/Spec.j...e1=yes&place=0
