Old 10-21-2010, 11:06 AM
g356gear's Avatar
g356gear g356gear is offline
Default 69 Camaro..Unequal length factory rockers??
We are getting close on my car after getting the quarters finished and getting the door gaps set. My metal guy found something a little off on the factory rockers. The pass side is 1/4" longer than the driver side rocker panel length. After media blast, we know the rockers are the original pieces, rust free and solid. Car has never been hit. The stock rocker panels are physically unequal in length. This may be the reason that I always had hood fitment issues with the car on the passenger front corner. Door to quarter and fender to door gaps were perfect but hood to header was always off. Has anyone seen this before on a factory original car??
Looks like we are going to have to section a piece out...about 1/4" long.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 10-21-2010, 04:04 PM
MaxHarvard's Avatar
Has the frame sagged?
Old 10-21-2010, 07:08 PM
g356gear's Avatar
Do you mean the unibody?
Old 10-21-2010, 07:32 PM
MaxHarvard's Avatar
Yup.
~Eric
Old 10-21-2010, 09:17 PM
Or it was tagged on one side from the rear maybe....
Old 10-22-2010, 05:26 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Maybe it was a Friday afternoon when that part was attached.
It's not like these cars were assembled with todays technology. It's a wonder they fit as well as they do. Bottom line is if you want it better now, it has to be fixed.
My "all original sheet metal" (that people like to brag about) Chevelle was off all over the place. Metal has to be added, things have to be moved.
Old 10-22-2010, 07:57 AM
DOOM's Avatar
DOOM DOOM is offline
Mine was the exact same way. I did some measuring before I blew mine apart and could'nt believe the differences from right to left. Some areas were as much as 10mm to 12mm differences. The cars today have only a 3mm tolerence in some areas to work with.Body tolerences were'nt a concern back in the day.As I put my rockers on Im finding out more about how these cars are put together and its a little scary. Rocker damage is hard to hide. So if the rockers have'nt been damaged,or any other critical area such as the cowl. Than I'm sure your shop will know what to do. From what I'm looking at these guy know what there doing thats for sure .Its coming along ,can't wait to see it complete..
Mario
USCOLLISION
