Old 11-16-2010, 06:18 PM
GM Muscle's Avatar
Default ram flywheel
Im getting ready to do an ls1 t56 swap on my sbc. i probably make 350hp at the flywheel.
ive been looking at flywheels and see that ram sells a billet flywheel for roughly $100 cheaper than mcleod or centerforce. Is anyone using the ram billet flywheel?
http://www.jegs.com/i/Ram-Clutches/7...oductId=751484
any opinions/suggestions?
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 11-16-2010, 09:14 PM
funcars funcars is offline
My .02:
I have a RAM Al flywheel and use their long p-plate and 6 puck disc in my Ford motor. Quality seems as good as anything I've used in my Fords or Chevys. I'd still balance the flywheel and clutch together for a neutral balance motor if it sees high rpms.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 11-17-2010, 05:32 AM
GM Muscle's Avatar
6k rpm at the most
