Old 01-18-2011, 01:43 PM
AM.MSCL's Avatar
AM.MSCL AM.MSCL is offline
Default Should I have my alignment checked?
Over the holiday I installed subframe connectors and replaced the worn out rubber body bushings (not radiator bushings) with solid body mount bushings.
We did nothing with the the front end, ride height or adjustment to the coilovers. Just curious if the body mounts could do enough to worry about?
Old 01-18-2011, 04:40 PM
Blake Foster's Avatar
should be no issues with the alignment.
Blake Foster
www.speedtechperformance.com
Old 01-18-2011, 05:55 PM
I agree with Blake. If there was a problem, it would be an off center steering wheel.
Old 01-19-2011, 07:27 AM
AM.MSCL's Avatar
Thanks. I figured it be a no issue but better to ask and be safe!
Old 01-20-2011, 05:29 AM
XcYZ's Avatar
XcYZ XcYZ is offline
How long has it been since you had it aligned? Might not be a bad idea to just have it done anyways.
My LS7 69 Camaro
Old 01-20-2011, 08:12 AM
AM.MSCL's Avatar
I had the car aligned last Sept/Oct (full front suspension replacement) and did the solid body bushings and subframe connectors between Xmas and New Years.
