Old 02-02-2005, 10:57 PM
68BlueBird's Avatar
68BlueBird 68BlueBird is offline
Default 68 F-body wheel size
Hi everyone, I'm new to the site, and the world of musclecars. I picked up a completely stock 68 firebird 350 4-speed car a few weeks ago. Amoung other things, I was wondering what size wheels I can run? I was thinking 16x8 all around, but i heard I may be able to go 9.5 in the rear with the proper offest. I'm thinking about getting a set of torq thrust 2's. Also, what offsets would I need for these wheels? And what tire sizes would you recommend? Keep in mind that I will be using the car as a daily driver, and maybe try to run her occasionally at a road course.
Thanks for the help.
Old 02-02-2005, 11:03 PM
jonny51 jonny51 is offline
I am pretty sure you can run a 17x9.5 with 5.5 BS and 275/40/17s in the rear.
Old 02-03-2005, 06:33 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Welcome, 68BB. Check out this thread:
https://lateral-g.net/forums/showthread.php4?t=89
Should be an excellent start to getting your TTII's.
Most people run 245/45's on a 17x8 with 4.75" of backspacing on the front and 275/40's on a 17x9.5 with 5.5" of backspacing on the rear.
My LS7 69 Camaro
Old 02-03-2005, 09:50 PM
68BlueBird's Avatar
Does anyone offer the rears at that backspacing? Seems like if I want 5.5' spacing with a 4.75 bolt patter, i need to order it custom built...
Old 02-04-2005, 07:06 AM
MaxHarvard's Avatar
I had to have my custom made, but American Racing will make them for you, they arent cheap... i know the owner of a Tires plus and got me them at cost, so that helped.
Retail for rear rims will be about 350-400 each. Then add tires, and your set
Old 02-04-2005, 09:41 AM
1968rsss 1968rsss is offline
i have 5.5 bs on a 9.5 rim,eagle alloy.
boyd also has alot of rims that would work but they would not work with c5 brakes I wanted to do.
Mark
Old 02-04-2005, 01:03 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Budnik will make them for you without any extra charge. I bought mine through DSE, give Kyle a call.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 02-05-2005, 07:25 AM
Steve Chryssos's Avatar
68BB,
To recap: The logic here is not a difference of opinion as to what will fit but rather two different approaches:
1) If you choose the no-brainer, off-the-shelf approach, it seems that an 8" wheel is all that will fit. But....
2) With a little homework, you can custom order a 9.5" or even a 10" wheel that will fit.
________________
Steve Chryssos
Ridetech.com
Old 02-10-2005, 06:38 AM
trapin's Avatar
trapin trapin is offline
68BB...I have a '68 Camaro and this is the set-up that I am running....
Billet Specialties HP-25. Rear: 17x9.5 (5.5bs) Nitto 555ZR 275/40/R17. Front: 17x8 (4.75bs) Nitto 555ZR 245/40/R17.
Hope it helps.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 02-10-2005, 12:50 PM
68BlueBird's Avatar
Thanks for the help guys!
I'm thinking I'll go with the new AR Trackstar S/S wheels.
Cheers.
