Old 02-05-2005, 01:06 AM
rockdogz's Avatar
rockdogz rockdogz is offline
Default MAP connector problem
This is puzzling me... maybe another in the long line of dumb questions, but what's wrong with me on this one? When I went to plug in the MAP sensor, the thing won't go in. So I pull it off and it sure looks like the metal plugs are both female... You'd expect one side to be male and fit in the female connector on the other side. What's wrong with me?
Bigger pic here.
-Tom
camarorestoration.com
-edited: MAP not MAF, thx Jody
Old 02-05-2005, 01:10 AM
Very hard to tell, but make sure you have the correct MAP sensor (not maf!). 1 bar (naturally aspirated) has one plug and 2 and 3 bar is another. The difference is in the little slots cut in the sides/tops of the plastic connector surrounding the pins. They make them different so you don't mix them up.
Old 02-05-2005, 01:18 AM
rockdogz's Avatar
BTW, the wiring harness and the MAP are both from the RamJet 502 crate motor, so I would think they should go together. Hmm.
-Tom
Old 02-05-2005, 01:22 AM
They should for sure. Let me go look at mine I can't remember if the harness is male or female.
Old 02-05-2005, 01:28 AM
Both of the ones I have are male on the harness and female on the map sensor.
Old 02-05-2005, 01:55 AM
rockdogz's Avatar
Hmm, weird. Maybe I got a defective plug on the harness. The small metal tubes that make up the plug on the harness side look like they're slotted - maybe I can bend them to a point so they fit...
-Tom
Old 02-05-2005, 01:59 AM
I'm thinking they screwed up and put female connectors instead of male. You should swap them out, not overly difficult with the right crimpers. There's a tool that looks like a screwdriver with what appears like a female tube on the end that slips over the connectors and releases the tangs that hold it in the plastic connector. I've also taken them apart with a small screwdriver.
Old 02-05-2005, 08:57 PM
lil427z's Avatar
lil427z lil427z is offline
get another map to see if they are the same . you will see that they are not . good luck.
rick kirkindall
