Old 09-23-2011, 08:17 PM
g356gear's Avatar
g356gear g356gear is offline
Default Start Up routine after 30+ year hibernation??
I have recently inherited a 64 Impala SS327 Convertible that my grandmother bought brand new. The car hasn't seen the road since the mid 1970's, 59K miles on the clock. It's been in heated, ambient storage all this time. I am looking for a checklist for getting the car ready to start again. I thought about the usual suspects, new plugs and maybe a carb rebuild. Any recommendations for getting it ready to fire after sitting so long? Here's a few pics as she sits now.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 09-23-2011, 08:23 PM
78SilverZ28 78SilverZ28 is offline
Wow looks like it was stored properly!
Fill the cylinders with marvel mystery oil and slowly turn the engine over by hand to free up the rings without damaging them, then turn over with the spark plugs out to spit out the oil. That should get the compression back up
Old 09-23-2011, 09:30 PM
  • Drain and clean the fuel tank
    Rebuild the carb
    Fuel Filter
    Fresh oil and filter
    New plugs
    New coolant
    New PS fluid
    Bleed the brakes
    New belts
    Trans fluid
    Air Filter
    Grease the bushings
    Prime the oil pump for 10 minutes
    Repack the front hug bearings?
    Check the rear end great or better yet, change
    Agree with oiling the cylinders and spinning it by hand first and then with the starter..
Old 09-23-2011, 09:33 PM
That looks awesome! Before you turn it over make sure to change the oil and use a primer tool and get the oil pressure up. Then you can put something on the crank bolt and turn it be hand. A little mystery oil in the cylinders is a good idea too. Plus everything Todd said.
Old 09-23-2011, 10:26 PM
GNon18s's Avatar
GNon18s GNon18s is offline
Lucky!!
Old 09-24-2011, 08:04 AM
clill's Avatar
clill clill is offline
First off I would see if you can turn the engine by hand. If it turns you are in great shape. Pull the plugs and squirt a little Marvel Mystery oil in them and let sit for a couple days.....
Actually...Just sell me the car. Beautiful car.
My 70 Z hadn't been started for 36 years and it was locked up tight. It is fine now and the lid has not been off the master cylinder since the car was assembled.
Old 09-24-2011, 08:07 AM
clill's Avatar
And pleeeaseee don't do any detailing-painting under the hood. People looking for survivors want them untouched. There are less and less of them left as people keep fixing them up.
Old 09-24-2011, 08:39 AM
NAPA 68 NAPA 68 is offline
Yes^^^^^
I'd think about replacing the fuel pump as well. The diaphram in the pump will rupture sooner than later. Great car!
Tim
Old 09-24-2011, 09:44 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Me personally, I would just get it rebuilt to make it trustworthy and roadworthy of 70 mph on a city highway. Now, I know that may not make sense to the masses, but that's just me. But, you must mark everything and make sure it is your block, etc. that you get back to keep it all original. By the way, beautiful car. The white seats are still as white as if they were stitched and covered today.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-24-2011, 11:08 AM
Tiger's Avatar
Tiger Tiger is offline
talk about a nice time capsule.
sorry bout the loss of your grandmother tho.
André
2009 Chrysler 300C Touring.
3.0 liter V6 diesel, five speed auto.
1968 Chevelle Coupe.
355cid, Viper T56, Corvette C4 IRS (Dana 44) and C4 IFS. Porsche 6 and 4 piston Brembo's.
1980 Chevy Van (shortie G10).
355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
*NOW PARTING OUT* 2000 BMW 540i Wagon*
Bikes
1968 Benelli City Bike
1990 Yamaha RD 350
1990 Yamaha TZR 125R
1991 Yamaha TZR 125R - RD350 engine, Aprilia RSV forks, RS250 wheels and shock
2010 Buell XB12SS
