Old 10-27-2011, 10:23 AM
JON Q's Avatar
JON Q JON Q is offline
Default Old subframe New subframe?
I am working on my 69 Z28RS (true) I am now in the stages of reassembling the car, so far I have done the DSE mini tubs and although I purchased the DSE 3" lowering leafs and offset shackles I decided I want to save money and go with quadralink... I ordered my Fikse profile 5s 18x12 in the back, still waiting for wheels to arrive from Driverzinc, its been bout 4months now.. I have a LS6 stroked to 427 by my friend Pecos @ LME (late model engineering) and Viper 6speed...
I will NOT be drag racing or autoXing the car, so for my stock subframe, I have rewelded, painted and have installed Speedtech upper and lower arms, tall ATS spindles and coilovers, for braking I will be running 6piston Z06 front and rear... QUESTION is, should I keep my sub with all the goodies? or sell it and order the DSE sub? And of course I am on a super tight budget..
Thanks for any suggestions
Jon
Old 10-27-2011, 10:43 AM
RBR's Avatar
RBR RBR is offline
I vote DSE sub!!!!!
Old 10-27-2011, 10:50 AM
JON Q's Avatar
One vote from RBR, thanks
Old 10-27-2011, 10:58 AM
Ron in SoCal's Avatar
Sounds like a great build. Budget and intended use usually drive these decisions. DSE is certainly top notch product, but if budget is tight and you don't need 10/10ths, you could keep what you've got as it will work really well.
Let's see some pics of your car?
Ron in SoCal
69 Camaro in progress
Old 10-27-2011, 12:46 PM
JON Q's Avatar
Thanks Ron!! I am not much of a fan on taking pics, but I do regret now that I didn't take any from the beginning, I was too lucky with my car that I did not have to replace any sheet metal, the only one I patched was a pin size hole onthe drivers fender.. here are a few pics with my phone camera, these 17x11 ZR1 wheels is what I used when I rolled it out of the paint shop, the Z is original daytona yellow, so I decided to go with the same..
Since I am intending on using the car just for cruising with a few blondes and brunettes, hahaha!!!! I figured I can always swap subs down the road..
Old 10-27-2011, 04:19 PM
Rybar's Avatar
Rybar Rybar is offline
Well if your not going to race it and or on a super tight budget why change what you have?
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 10-27-2011, 05:11 PM
Blake Foster's Avatar
No Reason to change the excellent product you currently have, there are cars out there that run with and can beat cares equiped with your option that have the same front set up you have now (One Lap Camaro ) for instance.
Blake Foster
www.speedtechperformance.com
Old 10-27-2011, 05:42 PM
vdrivinmike's Avatar
vdrivinmike vdrivinmike is offline
I'm with Blake and Ron on this one.
What you have now will work very, very well - especially recognizing that you don't plan to race Auto-x (and are trying to keep a budget in mind).
It sounds similar to my set up on a stock frame (except I have DSE suspension goodies instead of Speedtech goodies).
My car handles so much better than I am capable of driving it - I am not missing anything by not having the aftermarket clip.
BUT, if I do decide to upgrade and start racing, I'm going Speedtech front sub and rear!
Mike F
"ssmike" on PT.com
Old 10-27-2011, 09:51 PM
coolwelder62's Avatar
Keep your stock sub frame.My son is running stock camaro geometry,and is as fast as the DSE stuff on the autoX.Use the money for other things so you Finish the car sooner.Good luck.Scott M.
Old 10-28-2011, 08:07 AM
JON Q's Avatar
Blake, your product is great and customer service is excellent as well. I want to thank each and everyone of you that has replied for your input.. I will keep what I have now.. Scott you are correct, I better use that little extra money else where to finish my car.. I will post more pics as I do more progress on my car, still need a name for it,
Jon
