Closed Thread
Old 11-13-2011, 09:42 PM
That's awesome man... your pops just gave the word "payback" a proper definition today.
  #2542
Old 11-13-2011, 11:09 PM
Track Junky's Avatar
My spoiler is in pieces at Las Vegas motor speedway. He came out of the last corner and got a little greedy on the loud pedal. The rear end went one way and the other and you can guess the rest. I'm pretty certain it's payback for that 6k launch in his 199x Jeep Commanche that scattered his rear end. HA HA He was pretty jazzed at the end of the day. He drives one of them limp wristed C6 LS2's.
Thats great man!! You guy's will be laughin' about that one for years!!
Let's see......radiator, brake rotors,...............oh yeah, add front spoiler to the list
Gaetano Cosentino
  #2543
Old 11-14-2011, 12:38 AM
surprised the car didn't pull a blues brothers and fall into a million pieces as soon as you put it in the garage. Great to hear you and your father having a blast. My dad still knows im an a-hole. LOL
It would be cool to build him and surprise him with his own auto x Camaro.
  #2544
Old 11-14-2011, 07:23 AM
Funny -- I never once wrecked my parents cars or did anything remotely like that....
My '66 Corvette had A/C -- and my grandparents lived in Carson City, NV - so they wanted to borrow it for a trip. We swapped for a couple weeks. It came back with the nose busted up. I gave him crap about it 'til the day he died. It was the perfect 180* "out" situation.
  #2545
Old 11-14-2011, 09:23 AM
69x22's Avatar
69x22 69x22 is offline
First, let me say that she's a dirty pig right now. I've been busting my ASS trying to get it ready for a local SCCA autocross tomorrow. Rumor has it that it's the biggest lot we've ever run in at the speedway. As most of you know, my oil temps were hitting 275 at Buttonwillow. That doesn't make a guy feel to warm and fuzzy. So in typical fashion, I buy the 2nd biggest oil cooler Earls makes.(50 or 52 row) It was like stuffing a square peg in a round hole. I built a bracket and the oil hoses wouldn't clear the front facia. I built that bracket on the same angle as the grill. Then I designed a bracket that would put the oil cooler square to the radiator. It turned out bitchin. I had to re do my entire oil system. I moved the sender out to the oil t-stat. The oil lines go in around the Z bar area and it's a tight bitch with the 2 1/8" headers coming in to clear the steering shaft. I'm stoked with how it turned out. I'm going to redo the top aluminum cover plate and the hardware will change. I just flat ran out of time. My oil pressure is up 10-15% over the old set up. I don't know if it's from moving the sender or the heat exchanger was that restrictive. Dad and I took it around town today and it's definitely running 10-15 degrees cooler in traffic. I think it's going to work well in the summer and on the road course. I'm a little concerned with the cold weather cruise condition. I may fabricate up a cover for the oil cooler. The t stat is working but I think it's still doing some cooling just being full of oil. I switched over to Redline 15w-50 and it now takes 13 qts for an oil change.
One of my major goals was NOT to cover up a majority of the radiator but allow enough room between the core and radiator support for flow. It's a god mix of flow through the oil cooler, condensor, radiator, and through the oil cooler and into the radiator support and where ever the air wants to go.
The front brakes are TOAST. They were good in the last session at Buttonwillow. Today, they were spongy and it was 4 and I had a party to go to tonight. So I bled all four corners tonight. The front fluid was a little toast but the front rotors are done! Cracked and blue. They have been on there for 2 years. I hope they make it through the day tomorrow.
Oh yeah, I pulled the jabroni move of the century. I drilled a hole in my radiator. I was to lazy to remove the radiator. Long story short, I had about a half inch and was enlarging the t stat holes and went a little deep. It's epoxied up so it's getting replaced after this race. It will only be the 3rd radiator in this car.
I was going to throw the towel in on this deal after the radiator incident. Dad called and I told him the car probably wouldn't be ready. I could hear the disappointment in his voice and I manned up and I've spent about 15-20 hours out there this week getting the car ready. I even put his ass to work today. He cut the zip ties on the wiring harness above the t stat. ha ha After we got her running and warmed up I broke the news about letting him drive tomorrow. I hope he doesn't kill a cone worker.
Hey Todd, I noticed quite a bit of splines showing on that steering shaft. You may want to check it out. I know how racing tends to loosen things up.
  #2546
Old 11-14-2011, 09:33 AM
Thanks for the heads up. I'll take a look.
  #2547
Old 11-14-2011, 09:58 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Ha ha thats awesome man... sounds like you all had a great time. That will definitely be something to laugh about for years to come. Love your setup by the way... always been one to keep up with your project.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
  #2548
Old 11-14-2011, 12:24 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Yep, it's priceless. Everybody got a kick out of it. It was fun to watch and ride along. I could hear him bragging up the car to a group of guys when I was getting ready to run. My dad is a man of few words and he doesn't get to excited about much! 666hp tends to put a smile on about anybodys face.
AWESOME you are able to share this with your Dad! Those are moments that most can only dream of! I have had the privledge to the same and nothing compares! Those are times you both will reflect on for many years! Now send him the bill for the spoiler!
Brent
  #2549
Old 11-14-2011, 12:38 PM
Rybar's Avatar
Rybar Rybar is offline
Man that is pretty cool Todd. My old man is a little too old for anything like that, but I let him cruise my car before and he had alot of fun.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
  #2550
Old 12-09-2011, 10:09 PM
When it's hunting season...............................ya hunt.
Closed Thread
