Old 01-28-2012, 11:55 AM
ndm68 ndm68 is offline
Default TKO-600 with LS install kit-new
SOLD SOLD SOLD
Brand new never installed into project car Kiesler 5 speed complete conversion kit with LS2 engine
TKO-600 650hp/650ft-lb 5 speed, low profile internal offset shifter, keisler mini billet shift tower and lever stub, 4616 chromoly gear set, 1pc counter shaft, dual speedo outputs, reversed and neutral switch output,
ratios 2.87,1.89,1.28,1.0,0.64
GM performance synchromesh trans fluid
Complete flywheel/clutch combo for LS engine, pressure plate, disc, pp bolts and, Hurst classic 5 speed knob
Hydraulic kit, master cylinder, slave, throw out bearing, resevoir assembly, fluid lines and fittings
All new and never installed
Old 01-28-2012, 02:05 PM
NOPANTS68 NOPANTS68 is offline
left you a VM.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 01-28-2012, 05:11 PM
SOLD SOLD SOLD- to local Forumn member
