Closed Thread
Old 06-22-2012, 08:02 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
So when are you dropping them off?
When your Torino is as fast as a Ford GT, we'll talk. Better hurry though, there's no way you're getting them once I put them in my car.
Matt
  #112
Old 06-23-2012, 02:14 AM
Ron in SoCal's Avatar
1.8" below the pan rail. I think the bellhousing will be an inch or more lower than the pan. It will let the RS guys drop the motor low in the frame. Bummer when that stuff happens huh
Look into this Grasshopper...
Ron in SoCal
69 Camaro in progress
  #113
Old 06-23-2012, 11:33 PM
FETorino's Avatar
FETorino FETorino is offline
Matt
Define faster. David Pearson only got to 190mph at Daytona qualifying in 69 so my brick probably won't better the GT on top end even though I have more hp than the GT or Pearson. 1/4 mi drag race maybe.
I'll get nervous about you fitting those seats if you actually make some decisions on drivetrain and suspension for that Camarostang of yours.
The drivetrain will be as low in the frame as it can be, within reason.
Rob in SoCal
  #114
Old 06-23-2012, 11:44 PM
Matt
Define faster.
When the rubber meets the road. A lot of things are fast on paper and on the internet.
  #115
Old 06-24-2012, 09:36 AM
Deleted...
Ron in SoCal
Last edited by Ron in SoCal; 06-24-2012 at 09:51 AM. Reason: Asumption not correct - I'll call you Rob
  #116
Old 06-24-2012, 10:04 AM
FETorino's Avatar
Deleted...
Ron you can't just delete my thread. Only Dave can do that
Especially Camaros
Rob in SoCal
  #117
Old 06-24-2012, 10:41 AM
There is a Ford GT that shows up to most events so you can test your theory.
  #118
Old 06-24-2012, 11:46 AM
FETorino's Avatar
My only theory is it will be an exciting car to drive and something a little different.
Well Todd you know as well as anyone once I get this thing to the track it will be a long road of tuning to get it "fast".
I've chosen some good parts and am working with good people for the base. I'll have plenty of power delivery and a chassis with good geometry to tune.
Spring rates, sway bar rates, shock valving, air pressure, yada yada yada..... There will be a lot of things to sort out. Step one I just need to keep focused on building a running car.
Rob in SoCal
  #119
Old 06-24-2012, 11:56 AM
Agreed, get to to the finish line first, then the real work begins.
  #120
Old 06-24-2012, 12:17 PM
Matt@BOS's Avatar
I'm ordering part of the suspension next week, I had to wait until BOS's security system was free of bugs and working perfectly because I figured there was a chance a couple of seats might go missing.
Anyway, I'm sure your car will be an exciting ride. I'm sure it will be a handful, but that doesn't mean it will be slow, it just means that it will be fun to drive at any speed.
Matt
Closed Thread
