Old 06-26-2012, 09:27 PM
Rick D's Avatar
Rick D Rick D is offline
Default Backspacing???
So I tried searching but did not come up with an answer. With Backspacing the bigger the number the less dish you will have or is it the other way around? For example if I have a wheel with 3 1/2" backspacing the center of the wheel will be closer to back side of the hoop? Correct or am I messed up?? Well ok I'm messed up but that doesn't count
Rick
Old 06-26-2012, 09:35 PM
that would depend on the width of the wheel. Backspacing is measured by placing a straight edge across the inside lip of the wheel, across the center. Then measure from that line to the mounting pad of the wheel.
Old 06-27-2012, 01:33 PM
FETorino's Avatar
FETorino FETorino is offline
Jody is correct but to make it simple, even oversimplify; the more backspace the less front lip.
Rob in SoCal
Old 06-27-2012, 01:47 PM
Rybar's Avatar
Rybar Rybar is offline
Yes you are correct.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-27-2012, 06:57 PM
Rick D's Avatar
Thanks guys that's what I thought but someone was trying to tell different!
So just to be clear if the wheel has a stated BS of 3 1/2 on a 11" wide wheel then it should have a 7 1/2 front lip give or take for the center of the wheel?
Rick
Old 06-27-2012, 07:15 PM
it would have 7.5" from the mounting pad out to the outside edge of the wheel, but the lip wouldn't be that wide due to the center design, thickness of the mounting pad, wheel design and lip style, etc.
Old 06-27-2012, 07:51 PM
v8s only's Avatar
v8s only v8s only is offline
a 11 inch wheel its 12 inch from edge to edge so 12 minus 3.5 its 8.5 from mounting pad to front edge
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 06-27-2012, 08:19 PM
you are correct, but I was just trying to keep it simple and call the entire width 11" from edge to edge.
Old 06-27-2012, 09:11 PM
Rick D's Avatar
Ok I got it now thanks guys!!
Rick
