Old 09-09-2012, 06:34 PM
parsonsj parsonsj is offline
Default II Much Fabrication Fuel and Differential Vents are in stock and ready to ship
The II Much Fabrication Vent solves several problems when installing high performance fuel tanks. It allows the use of an unvented fuel cap, preventing fuel slosh and odor, while providing filtered air to the tank via its integrated 40 micron filter. The Vent also works well as a differential vent, allowing the rear end assembly to breathe, and helping to eliminate differential fluid seepage and leaks. The new design allows for simple plumbing to a fuel tank or differential: mount the Vent, and connect it to the tank or differential vent port. It's that easy.
Go here to order: http://www.iimuchfabrication.com/fue...fuelvent2.html
John Parsons
Old 09-09-2012, 07:55 PM
coolwelder62's Avatar
I ordered mine today.They are a great pc.
Old 09-09-2012, 08:00 PM
that's a great looking piece, and it solves a very common problem for a lot of guys.
Old 09-10-2012, 09:21 AM
carbuff's Avatar
carbuff carbuff is offline
I have two of them sitting here, and I can attest that they look as good as they do in that picture...
Too bad they get hidden in the trunk...
Old 09-12-2012, 06:58 AM
Jay,
Yes: our vent, along with an unvented cap, is designed to solve that problem.
John Parsons
Old 09-12-2012, 08:06 AM
Excellent!
Hector (at Rick's) has been referring his customers to us for this issue.
John Parsons
Old 09-12-2012, 10:26 AM
It will go out today; overnight to you. We love to see installation pics.
Thanks very much for the order!
John Parsons
Old 09-12-2012, 11:00 AM
Jay,
To connect the vent to the tank, you'll need a 6AN ORB fitting for the vent side, and a corresponding fitting for the tank (1/4 NPT to 6AN, probably), plus the hose or hardline to make the connection.
Here's a couple Earls's 6AN ORB fitting PNs (985006ERL or AT949068ERL) to get you started.
John Parsons
Old 09-12-2012, 11:42 AM
Rybar's Avatar
Rybar Rybar is offline
This is fantastic, I have been fighting the same issue for a long time and thought only the vaperworx tank was the proper solution. Going to order one as well.
Can you post a picture of one installed? Or are there instructions?
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 09-12-2012, 11:45 AM
Originally Posted by Jay
Do you think it would be OK to use the existing line and go to an 8AN to an 6 ORB into the vent?
You bet. That's what I would do too.
John Parsons
