Old 10-02-2012, 05:31 PM
Thought you guys might get a kick out of the engine spec in the new 'rig'...
It's 781 cubic inches
470 Horse power
1650 ft lbs of TQ
Bore = 5.2 Inches
Stroke = 6.15 Inches
Compression ratio = 17.3:1
Holds 42 Quarts of oil
500,000 mile "major component" warranty
EEEEEEEHHHHHHHHHAAAAAAAAAA
If geared correctly - best fuel consumption is at 1400 RPM @ 65 MPH
If you gear for a little extra sprightliness -- you gear for 1500 RPM @ 65
Old 10-02-2012, 05:52 PM
Sieg's Avatar
Sieg Sieg is offline
Only 10.5 gallons of oil huh? Oh the shame of environmental irresponsibility.
You need to commission this guy to do a GW hood ornament for that beast!
http://www.browndogwelding.com/
NICE TRUCK!
Old 10-02-2012, 05:58 PM
Scott,
I was laughing to myself when reading these specs.... they just seem so "out there". 781 cubic inches! Really! Holy moly!
Old 10-02-2012, 07:41 PM
Lateral-g Moderator
Scott,
I have a motorhome on a columbia chassis that has a MB 450 hp diesel, you won't believe the torque your truck will have.
Old 10-02-2012, 07:55 PM
I may have gone "overboard" --- but I'd talked to other friends that had the smaller 330HP 1000 TQ Cummins -- and they weren't happy.... and the other option was the 450 DD/MB engine so I figured I might as well go for the top of the line version. I'll never wear it out.
The trailer is spec'd out at 20,000 pounds -- so even fully loaded it's only going to be 35,000 with two cars and everything else I can drag along. The truck is rated to haul 62,000 or something like that.
Old 10-02-2012, 09:32 PM
Sieg's Avatar
Scott,
You are going to have a lot of fun with this.
Personally I'm really interested to see what it turns in the quarter.
Old 10-02-2012, 09:41 PM
intocarss's Avatar
470 Horse power
1650 ft lbs of TQ
Bore = 5.2 Inches
You realize you're king of the hill
Old 10-03-2012, 06:54 AM
Those are some impressive numbers huh buddy!?!?!
I'm not sure why I hadn't done any snooping around on the motor - but when a buddy asked me - I started to investigate and I was blown away by the SIZE of this thing. 6" stroke OMG! And that 5" piston.... But of course -- Max rpm is limited to 1800... well DUH! You suppose they balance each rod and piston to + or - a pound??
Old 10-03-2012, 06:57 AM
The man already has an ego the size of Montana. And the truck to go with it.
Old 10-03-2012, 07:22 AM
You could have picked a bigger state....
