Old 12-27-2012, 09:12 AM
Lous69 Lous69 is offline
Wow, sounds like that Formula SAE program at the University of Missouri- Rolla (UMR), which is now called Missouri University of Science and Technology), served to create some heavy hitters.
Mark Stielow,..... Kyle Tucker and now we learn Dave was also part of that program. Very Impressive.
Old 12-27-2012, 09:37 AM
clill's Avatar
clill clill is offline
He's not doing white ! I'll Killllllll himmmmm.........
Old 12-27-2012, 09:43 AM
start working on your alibi........
Old 12-27-2012, 10:23 AM
Originally Posted by GrabberGT View Post
Sorry. Im not a Camaro guy but in this pic it looks more like a frame plate rather than a rail. Is the frame rail really cut that narrow for the mini-tub? Another pic from another angle would help clarify.
Thanks for the detailed build info.
Yes, depending on the fabricator it can get down to a 1/2" in that spot. Behind the area where Mark added the plate. But remember it is heavily reinforced in that area with 2 0.120" plates. Probably stronger than stock. Then add the strength from the cage down bars.
fleet's Avatar
fleet fleet is offline
Hopefully Whirpool doesn't sponsor Mark then...cuz their new style replacing stainless is 'White Ice', and it'll be all over that car.
Old 12-27-2012, 10:25 AM
JKnight JKnight is offline
I always thought Camaro X looked killer in white. I was very surprised you (Charley) had so much trouble finding a buyer for the car in white. I didn't have the stack of bills available to make my opinion matter though...
Old 12-27-2012, 10:31 AM
Originally Posted by ratman67 View Post
what is heat rejection????
the removal of heat from a heat generator. Water to air cooling or the exhaust. In this case he was referring to the inner cooler or heat exchanger efficiency.
Old 12-27-2012, 11:25 AM
JohnC JohnC is offline
That's kind of funny because that was one of the reasons I intiatially bought it (an original 50 50 code - Dover White car). ...in addition to it being a pretty solid CA black plate car.
John
Old 12-27-2012, 11:45 AM
mikels mikels is offline
In this case, there is 3 sources of heat - engine, supercharger and AC. Breaking that down further, engine heat in form of coolant and oil, supercharger heat in form of air and AC in form of refrigerant.
Engine heat in coolant and oil comes from the inefficiencies of an IC engine - only about 1/3 the energy released from combustion actually makes power, another 1/3 goes into cooling system (coolant & oil) and 1/3 goes out exhaust.
Since this is a SC engine, also have to take into account mechanical energy used to drive supercharger - in Red Devil and Mayhem, this worked out to ~120-140HP. So Mayhem generating an output of 878 HP is actually generating over 1000 HP already - and that also nearly equals the amount of energy we need to release from cooling system.
Complicating this further, we have the heat from the intake air charge to reduce as well - and use air-to-water heat exchanger with a stand-alone cooling system to then convert this with a water-to-air heat exchanger in front of car. Since delta-T is critical for heat exchanger effectiveness, we package the intercooler radiator in front of the cooling stack (all the heat exchangers in front of car) to get greatest delta-T for charge air cooling. This adversely effects radiator efficiency as air temp reaching front face of it is already heated above ambient. And we have 1000+ HP worth of heat to dissipate from it.
Packaged between the CAC (charge air cooler radiator) and the coolant radiator is the AC condenser. At least Mark hasn't become too much of a wimp is his old age to want to race with AC on, so while this doesn't add heat to air flowing through, it does add pressure drop of airflow through entire cooling stack.
We also have engine oil to contend with - and can either use oil-to-air heat exchanger, or oil-to-water. If oil-to-water, this is more KW to release through radiator. If oil-to-air packaging, airflow restriction and preheated cooling air have to be considered.
All this is converted to heat transfer equations and calculated to optimize the entire cooling system of heat rejection balance.
Drag racing is easy - you can get away with a whole lot if only running in <10 second bursts of WOT. Road racing makes this much more difficult as entire system reaches equilibrium.
And haven't even talked about trans and diff oil cooling yet....
Dave
Old 12-27-2012, 11:57 AM
Wow, very cool, Dave. ...you are an awesome dude.
John
