Old 01-25-2013, 11:15 AM
glr0212 glr0212 is offline
Brakes - Front brakes are from Tobin at Kore3. Can’t say enough good things about this guy. He was available to answer my questions and was more than willing to help me out every way he could.
Nothing really to report. Everything bolted up as expected. The only problem I have is when I got the tires mounted they put a valve stem on the inner hoop which hits the brakes when the wheel rotates.
Old 01-25-2013, 11:26 AM
Engine/Trans
I really wanted an LSX motor but couldn’t justify it since I had already purchased this 350. In my defense, I bought it in 2005 and had no idea the car was going to take another 7 years to make it home. Luckily it still runs well after sitting in storage. I guess 490HP is nothing to sneeze at… but then again its not a 600HP fuel injected motor either.
I bought a Magnum trans from American Powertrain. These guys were ok but I’ll probably give hurst a shot on the next go around. Not really a fan of the slave cylinder setup and the idea of pulling the trans to make adjustments after break in (per the instructions). Overall they had decent service, only slight beef I have is that I got the feeling at one point they were trying to scam me on the shifter but they made things right quickly after I called and did the WTF thing.
Old 01-25-2013, 11:45 AM
MHORTON79 MHORTON79 is offline
Subscribed. Off to a really good start. I'm also in Houston. Pearland to be exact.
Old 02-10-2013, 09:48 AM
so update on the dynatech headers.
Apparently the headers are made for heads that are 18-1/8" from flange to flange. The dart heads i have are just over 1/2" wider, hence the clearance issues with the gear box. I talked to the dynatech rep and he was helpful. I suggested they move the 7 tube back in around 1/4" we will see what they say.
So that doesn't help me now so it looks like i may end up with a Borgenson steering joint to get the clearance I need.
here is the "special" tool i made so I could get to a couple of the bolts
Old 02-10-2013, 09:57 AM
The other thing i'm working on is the fuel pump.
I have a carter 172gph but I'm wondering if the diaphragm has deteriorated since it sat for 5 years. I put the suction side in a gas tank and the discharge into a bucket and turned the engine over but got 0 flow.
It appeared there was some fuel in the pump but nothing came out the line.
disappointing
I'm going to connect the pump to the carb and fill the bowl, crank it and see if it makes 5psi.
if that doesn't work I'm going to get a 20$ stock pump and see if that one works.
They don't make the carter 172 pump anymore so I have no idea if i can get a rebuild for it.
any recs for a high flow pump?
Old 02-10-2013, 11:53 AM
DETON8R's Avatar
DETON8R DETON8R is offline
I thought Edelbrock bought Carter in the 1990's. Did you check out their catalog for a rebuild kit?
DETONATOR - 69 Camaro RS
Old 02-10-2013, 05:09 PM
I think there are two different companies named carter.
Anyway, got it running. I had to loosen the pump to assemble the fittings and must have dropped the rod. Fixed it and it started like a champ.
https://www.youtube.com/watch?v=Ujn7...e_gdata_player
Old 02-10-2013, 05:16 PM
Roberts68 Roberts68 is offline
Glad you got it running. Have to love the easy fixes.
Video Sounds like the microphone didn't deal with the exhaust note very well but I liked what I could distinguish... mean sounding idle.
Pretty sacreligous shop t-shirt for firing up the sbc dontcha think?
Old 02-10-2013, 07:15 PM
tmadden's Avatar
tmadden tmadden is offline
Originally Posted by SIXX View Post
Great project!!! I am also near downtown (Medical Cntr)... I am also working on my 69 Camaro Z28RS (true ZRS) I am putting my car back together right now, DSE tubs DSE subframe connectors,DSE Quadralink and their 9" rearend.. C6Z06 brakes, upper and lower control arms, AFX spindles, coilovers, LS3/TR6060, Fikse Profil 5S race black center, polished lip, 18x12 rears, 18x9 front.. originally Daytona yellow, so I went back to the same minus the stripes..... Good to see more people here from HOU....
Sounds Sweet!!
Old 02-10-2013, 07:18 PM
tmadden's Avatar
Car is looking great. Keep us posted!!
