Old 01-30-2013, 06:01 PM
IMPALA MAN IMPALA MAN is offline
I built this for less than $350. It bolts together, is made of 5 X 5 square tubing and allows me to work under the car if needed.
Old 01-30-2013, 07:20 PM
Firebird-Geek Firebird-Geek is offline
Why not make something like these?
I actually own a set of "skates" for moving the car around the shop... Just don't own any wheels to set the car on the skates... it came with 15" cheep aluminum wheels with 7/16th wheel studs... I now have 1/2 wheel studs. So these would neither clear the brakes, or bolt up to the car without drilling out the wheel studs... not sure if a person can do that effectively?
Someone said S10 compact spares (94-02) work with larger brakes...??? My brakes are 13" Wilwoods up front 12" in the rear.
1967 Firebird Convertible
Jarrod
My Build:
https://lateral-g.net/forums/showthread.php4?t=32878
Old 01-31-2013, 08:34 AM
Apogee Apogee is offline
There are two common type of lug nuts used on muscle cars, 60 degree conical seat and shank type, both of which are readily available in 7/16-20 and 1/2-20 sizes and can be found for cheap.
Tobin
KORE3
www.kore3.com
Old 01-31-2013, 10:16 AM
syborg tt's Avatar
I have a set of 16" GMC Typhoon Spare that I used on my 70 Camaro project. All I did was remove the caliper and mounted them up.
Kenny has claimed my GTO Spare and I am pretty sure I am not getting them back.
$75.00 plus shipping. I can band 2 together and ship them via UPS
marty-mj
