Old 03-08-2013, 09:37 AM
intocarss's Avatar
Green is better than Pink. Got it.
And EFI is better then Carbs
Old 03-08-2013, 10:09 AM
Sieg's Avatar
Sieg Sieg is offline
Old 03-08-2013, 10:58 AM
fleetus macmullitz's Avatar
That fool lets that happen to him...not this guy.
Old 03-08-2013, 11:57 AM
intocarss's Avatar
Old 03-08-2013, 02:03 PM
Track Junky's Avatar
Have you tried bumping up the discharge nozzle size yet?
Gaetano Cosentino
Old 03-08-2013, 06:02 PM
Sieg's Avatar
Mine came with Pink as well. It's for drag racing and absoutely horrible for throttle response. I'd jump up to orange as it delivers better volume on tip in..... I'm pretty positive that's the cam I used.
Money! Thank you.
Still not ideally crisp but in the range now. The pump arm was at about .002 freeplay, I'll experiment lengthening/shortening the link +/- one flat of the nut and see if that helps.
Old 03-08-2013, 06:13 PM
Sieg's Avatar
No, but were getting there! 31's in it now, 33's and 35's are probably worth testing.
It felt pretty strong with smooth primary to secondary transition in 3rd & 4th gear hard roll on's this afternoon.
Old 03-10-2013, 06:41 AM
protour73 protour73 is offline
Sieg, here's great spec chart for Holley accelerator pump cams. The amounts are per 10 strokes of the pump arm and it is based on a 50cc pump, but is a good visual to see the differences when adjusting the cam position.
Old 03-10-2013, 09:05 AM
DaleTx's Avatar
DaleTx DaleTx is offline
Big flat spot (as I'd call it) no blubbering, then it's fine. If I rev it and don't let it come all the way down to the 1K idle, say 1500 rpm, and crack the throttle it's fine. This has all been while actuating the throttle by hand.
After reading this.... I was thinking maybe you should try advancing the cam a few degrees and see if the response off the bottom gets better. Maybe it's just a matter of changing the valve timing events slightly.
Just throwing out another thing to try.... not sure if you considered this or not.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 03-10-2013, 01:45 PM
Sieg's Avatar
Thanks Scott, I haven't seen the volumes charted before, nor the WOT pump arm dimension measured.
Dale - The orange pump cam removed the off idle flat spot. What threw me was I thought I had eliminated the flat spot and bumped the initial timing which resulted in a big flat spot no matter what the initial timing was set at. I still don't understand what factors caused that to happen. Without an AFR monitor I'll assume it was lean to real lean in the transition and the motor could have loaded up a bit and when the timing was set it cleaned up at emphasized the lean condition.....
Based on the morning test drive it appears I'm finally heading in the right direction now.
