Old 06-09-2013, 10:37 PM
Hotrod1's Avatar
Hotrod1 Hotrod1 is offline
Default Car blocks
I know this may seem elemental, but how do you build the 2x4 wheel blocks (in place of jack stands) to raise a car up to on and work under? dont want to try and re-invent them and want to rely on safety. How high can you make them? Nails, screws, how many, how long of material, etc. In fact, I dont even know what you call them.
Thanks in advance.
Old 06-10-2013, 01:20 AM
proper term is cribbing blocks. They use these to lift houses from their foundations.
Heres a great write up to make a sturdy set.
http://www.myturbodiesel.com/1000q/multi/wood-block.htm
Tire size will determin width and length. I have found that 16" long and wide works well for tires up to 345 mm. I like to use 2" wood screws in case I want to lower or increase the height easily.
Old 06-10-2013, 10:17 AM
Hotrod1's Avatar
Thanks, I appreciate it.
Old 06-10-2013, 10:32 AM
Ron in SoCal's Avatar
Agree w Vince. Some guys do 16" x 12" ...
http://www.pro-touring.com/showthrea...ght=car+blocks
Ron in SoCal
69 Camaro in progress
Old 06-11-2013, 12:27 PM
MaxHarvard's Avatar
I did mine 18"x18" square.
Old 06-11-2013, 06:13 PM
Let's see a pic of your car on the 18x18 version.
Old 05-23-2016, 10:39 AM
alvin3a alvin3a is offline
Built these this weekend 17"x12" screwed together cost me about $45 and took about a 1/2 hr for each one. Which seemed like a long time but it was a lot of screws
Alan
Old 05-23-2016, 01:24 PM
Panteracer's Avatar
Default Car Blocks
I made up a set of these last year
They work great and give you a little
more stability in earthquake country
Nice job
Bob
Old 05-23-2016, 03:19 PM
BMR Sales's Avatar
Nice job
Bob
Always wondered how you guys get under a car with any confidence when the ground could shake at any time!
Old 05-23-2016, 10:02 PM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default 2x4 stands
I went 16x12 i believe. I went just high enough where my big floor jack could get to the bottom of the housing. Stable as can be. No clue why the pics are upside down.....Buy a Mac they said.....
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
