Old 06-22-2013, 09:26 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Default 1969 Camaro Headliner
I have done 4 headliners in 69s and they all were PUI and they have had the same issue.on the last bow to the rear the material has a bad area in the center and just wondering if anyone knows of any better brands that have better quality?
Old 06-22-2013, 06:47 PM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
What has been the problem? Just curious
TRACY WEAVER
www.recoveryroominteriors.com
Old 06-22-2013, 08:28 PM
tubbed69's Avatar
the last seem towards the rear in the center has one side stretched tight and the other side has a little slack in it and it will not stretch out,I will try to get some pics
Old 06-23-2013, 11:38 PM
Musclerodz's Avatar
I just did one over the weekend and had a similar issue. I am pretty certain the issue is with the listing being too loose. It will not let you pull an even stretch. Steamer helps alot, but still had a small wrinkle when I finished.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-24-2013, 05:23 AM
tubbed69's Avatar
thanks,I hate that you had the same issue,it just wont let you pull the last section tight enough and leaves that spot in the center,could be worse but I really want a nice job
Old 06-24-2013, 06:19 AM
coolclassiccars's Avatar
coolclassiccars coolclassiccars is offline
Default steamer
well since were on the topic anyone know where to purchase a good steamer.been using a heat gun on most of the headliners , but was thinking of getn a steamer.thanks shawn
Old 06-24-2013, 08:39 AM
tubbed69's Avatar
good question Shawn I was wandering about getting one also
Old 06-24-2013, 08:55 AM
Sieg's Avatar
Sieg Sieg is offline
I've had two of their professional J-4000DM steamers in the past 30 years: http://www.jiffysteamer.com/
Old 06-24-2013, 11:39 AM
tubbed69's Avatar
thanks Sieg I will check them out
Old 06-24-2013, 11:53 AM
TMIProducts's Avatar
TMIProducts TMIProducts is offline
We manufacture Camaro headliners. All of ours are made here in the USA, about 50 feet from my desk.
We've been selling them for quite a few years and I've never heard the issue that you're dealing with. Sounds like their patten is off just a little bit.
Let me know if you have any other questions!
www.tmiproducts.com
Our 66 Chevelle Build Thread:
http://www.chevelles.com/forums/showthread.php?t=285211
