Old 07-06-2013, 08:06 AM
no go nova's Avatar
no go nova no go nova is offline
Default Johnny joints
Has anyone you johnny joints in place of heim joints for front upper and lower control arms?
http://www.currieenterprises.com/ces...nnyjoints.aspx
Old 07-07-2013, 07:52 AM
MarkBsae MarkBsae is offline
Those are designed for movement that includes axial misalignment and in a typical A arm your pivot axis travels through the two inner connections. It seems those joints are designed for considerably moe axial misalignment than your typical A arm will encounter. Plus they are rather big.
my .02
Old 07-07-2013, 10:30 AM
no go nova's Avatar
They make them smaller. What I like is being able to grease them, and a better ride on the street.
Old 07-07-2013, 09:50 PM
ironworks's Avatar
Not quite sure how they are going to ride any smoother then rubber press in bushings.
Old 07-08-2013, 01:43 PM
79 Camaro 79 Camaro is offline
I was wondering the same thing. They could give you more articulation and be much quieter than the typical "groaning" poly bushing I have on a Heidt rear four link. Even after greasing it doen't take long till they are noisy again. I thought I saw Art Moorison is offering them on their four links now.
Old 07-08-2013, 02:53 PM
Sieg's Avatar
Sieg Sieg is offline
Page 23 of their catalog show the rod end options with features and benefits.
Apparently Strange Engineering is the original designer of the Johnny Joint.
Old 07-09-2013, 04:50 PM
ironworks's Avatar
In a 4 link application they work great. The OP talked about using them on his upper control arms in place of his rod ends.
